Db1 rear hugger
DB1 860
PostPosted: Mon May 08, 2017 11:04 pm    Post subject: Db1 rear hugger Reply with quote
Ive seen a few different style huggers on DB1's over the years,
As I'm pulling the swingarm out and replacing the shock, I thought I could also look at fitting a hugger.
Does anyone know are they an accessory or off a different bike like a F1 or a SS Ducati?
Quadrasuarass
PostPosted: Tue May 09, 2017 9:35 pm    Post subject: Reply with quote
I used a hugger from an 851 Tricolour that was parted out (16" wheels). I cut it down and freshened it up to suit then had Steve Bridge at F1 Engineering make up an Al mounting bracket that was then painted black.
Nigel
[/img]
DB1 860
PostPosted: Sat May 13, 2017 2:24 am    Post subject: Reply with quote
Thanks for that Nigel, it looks very smart, its given me some ideas.
Is that a Wilbers shock that I can see, are you happy with it? as that's what I've ordered for my DB1
Gerald
Quadrasuarass
PostPosted: Sat May 13, 2017 4:15 am    Post subject: Reply with quote
Shock is Maxton with high and low speed damping, M1R forks have also been fitted out with Maxton cartridges compete with compression and rebound damping adjustment; they did a great job and even retained the reservoirs on top of the forks. I can't comment on performance of the suspension as the bike is still coming back together; however Maxton have an excellent reputation when it comes to road and track set ups.
Nigel
Quadrasuarass
Nigel
PostPosted: Sat May 13, 2017 4:31 am    Post subject: Reply with quote
Nice touch. The hand made bracket is very Bimota Wink
Current rides - '99 Bimota DB4, '96 Bimota SB6, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Track Bike, CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250,
DB1 860
PostPosted: Sat May 13, 2017 6:57 am    Post subject: Reply with quote
Now that you mention it I can see the name Maxton on the spring in photo number 5.
I had my M1R forks serviced just recently and they felt alright,
but I wonder if the new shock is going to show up these forks.
Quadrasuarass
PostPosted: Sat May 13, 2017 9:48 am    Post subject: Reply with quote
The M1Rs are OK if a little under-dampened on rebound which can probably be tuned out by someone who knows how to set them up properly. The rear shock, however left allot to be desired - my one was best destined for the bin.
Cheers Nigel
