Looking for help from spain - db6
Xarly
PostPosted: Sun Jul 02, 2017 9:29 pm    Post subject: Looking for help from spain - db6 Reply with quote
Hi my name Xarly
I bought a couple of weeks back a bimota db6 deliro whose previous owner had a bad frontal crash. As a result of that, there was damage in the front forks, front fenders (mud guard), steering bearings, headlight, front wheel, discs and some of the fairings.
As I found out it's nearly impossible to find these parts in Spain, and I wanted to know if you knew of a dealer, or where to find them, since otherwise the bike can not be used again.
Thank you for your help.
arsenic
PostPosted: Mon Jul 03, 2017 3:00 am    Post subject: Reply with quote
Ouch, that's a lot of parts that you need...
Currently, Bimota is moving to a new warehouse, so reaching them in Italy won't have much succes...
Try to reach Paolo Girotti from Bimota Classic Parts (search it on Facebook) to see if he have some parts for you.
But honestly....good luck.
ralfweber
PostPosted: Mon Jul 03, 2017 10:01 am    Post subject: Reply with quote
http://www.subito.it/accessori-moto/bimota-db6-delirio-forcella-varese-205168621.htm
Xarly
PostPosted: Mon Jul 03, 2017 6:09 pm    Post subject: Reply with quote
Thanks, i write in the Facebook.
Xarly
$$$$$ Crying or Very sad
Xarly
PostPosted: Mon Jul 03, 2017 9:21 pm    Post subject: Reply with quote
Do you of any other bikes using the same headlight, and any other model using the same front wheel or equivalent?
I am going to be able to repair the forks but not the wheel, so I would need the same or something similar enough to make it work
Thanks!
arsenic
PostPosted: Mon Jul 03, 2017 11:13 pm    Post subject: Reply with quote
For the wheel you should ask directly with Oz racing and not Bimota...
Xarly
PostPosted: Tue Jul 04, 2017 5:53 am    Post subject: Reply with quote
This is oz or marchesini?
PostPosted: Tue Jul 04, 2017 7:11 am    Post subject: Reply with quote
Thanks!
Never managed to find out what the headlight is off but is the same as DB5/11 and BB3 .
Wheel is the standard Bimota one , same as standard DB5 , not sure of manufacturer but I dont think its Oz or marchesini, Marvics and Oz are used on the R version's.
PostPosted: Tue Jul 04, 2017 4:20 pm    Post subject: Reply with quote
If headstock bearings were broken or damaged.... Have you checked the frame for straight?
Gavin944888
PostPosted: Tue Jul 04, 2017 5:44 pm    Post subject: Reply with quote
Hello.......the Benelli TNT 1130 is a very close design and very cheap alloy version alternative
NOT usual Bimota standards but needs must if no immediate alternative.
Most items were not exclusive to Bimota and although the new factory opened yesterday..
.......no orders are being accepted for parts until ALL the boxes have been unpacked!
....do not ask how I know...I have been waiting to place an order since MAY
Regards
Gavin
Cagiva Elefant 999r engined
BIMOTA DB7-11 VLX MULE (project build with no end)
Xarly
PostPosted: Tue Jul 04, 2017 8:32 pm    Post subject: Reply with quote
The frame is repair now
Xarly
PostPosted: Tue Jul 04, 2017 8:34 pm    Post subject: Reply with quote
Regards
Gavin
Thanks, what is the email to contact with bimota?
Bennelli tnt1130 wheel is compatible?
PostPosted: Tue Jul 04, 2017 8:59 pm    Post subject: Reply with quote
I think I have seen that Bimota Classic Parts have the headlights , 350 from memory but can not find it advertise anywhere now.
Gavin944888
PostPosted: Wed Jul 05, 2017 6:12 am    Post subject: Reply with quote
The Benelli wheel is NOT a straight 'bolt in' alternative BUT is of a similar design and at a fraction of the price.
The bearing size on the TNT wheel is 30mm but they use a sleeve to reduce it down.....you could machine a new spacer to fit the spindle you have,
I have used these wheels until the correct ones are available or at a secondhand price.......buying a single wheel from the 'official outlets' is very expensive.
Bimota do not really answer emails ...they prefer that you go via one of the parts people rather than direct to the factory
I hope that this helps
Gavin
