DB 7 front brake disc
Number2
PostPosted: Wed Jul 19, 2017 3:02 am    Post subject: DB 7 front brake disc Reply with quote
If I want to replace the disc what other bike(s) use the same disc. I think there are some model Ducati that use the same
PostPosted: Wed Jul 19, 2017 1:08 pm    Post subject: Reply with quote
Think they are common with most 320mm /10mm offset Ducati discs from 916-1198.
Think Pantyless uses 330mm
PostPosted: Wed Jul 19, 2017 5:47 pm    Post subject: Reply with quote
As Vort says....discs are brembo 320mm.....last 4/5 years of Ducati stuff they moved to 330mm diameter on their big bikes....so be careful
Number2
PostPosted: Mon Oct 09, 2017 3:59 pm    Post subject: Reply with quote
not sure if you found something but another alternative is BrakeTech. They make a wonderful product and I have their Cast Iron rotors on my MV F4 which are some of the best around
