Steering bearings
Gammaboy
PostPosted: Tue Sep 12, 2017 12:28 am    Post subject: Steering bearings Reply with quote
Can someone tell me the dimensions of the hard to find barrel roller steering bearings used on the adjustable steering angle setups? Want to see if they'll work for something i want to try (non Bimota)
Thanks
PostPosted: Tue Sep 12, 2017 2:02 am    Post subject: Reply with quote
Yep.
OD 55mm
ID 26.5mm
Thickness outer race 10.46mm
Thickness inner race 12.50mm
Gammaboy
PostPosted: Tue Sep 12, 2017 6:13 am    Post subject: Reply with quote
Thanks!
Mike Jennings
PostPosted: Fri Sep 22, 2017 8:42 pm    Post subject: Bearings Reply with quote
Hello,
how do you adjust the adjustable bearings? Is this the setup on the SB2, HB1 etc.?
Cheers, MikeJ
PostPosted: Sat Sep 23, 2017 3:05 am    Post subject: Reply with quote
If they SB etc are the same as the YB series, you remove the upper insert which oem would have the bearing centred, and machine a new insert out of a bit of billet that has the the center hole ID offset in relation to the OD this way you can increase or decrease the fork angle in relation to the frame.
PostPosted: Sun Sep 24, 2017 12:28 am    Post subject: Reply with quote
I think the MK1 SB6 had excentric collars which held the bearings. Not sure about the earlier sb's.
