Wanted - front brake light switch SB6R
Spongebob
PostPosted: Sun Aug 13, 2017 4:12 pm    Post subject: Wanted - front brake light switch SB6R Reply with quote
Anyone in UK got one or can tell me what other bikes might have the same type? Mine's stuck on. Tried spraying WD40 in the the switch but makes no difference and its a sealed unit
Andrew034
PostPosted: Sun Aug 13, 2017 6:05 pm    Post subject: Reply with quote
My SB6 has the same Brembo brakes as top line Ducati's of the era (right up until the end of the 998 series).
Normally the the switch is part of the master cylinder, so getting a switch separately might be problematic unless someone has a dead master cylinder with a good switch for you.
Andrew...
Spongebob
PostPosted: Sun Aug 13, 2017 9:10 pm    Post subject: Reply with quote
plan b is just to put a banjo switch in place instead
PostPosted: Mon Aug 14, 2017 9:49 am    Post subject: Reply with quote
Ducati dealers stock the switch....either the type that has 2 screws/nuts...or the one with plastic lugs on them.....Have also heard that for a fraction of the price....the likes of Tandy stock them...micro switch
