Posted: Sun Sep 03, 2017 6:29 am Post subject: YB8 Builds |
I've got a few YB8 projects on the go (1 roady and two race bikes), and as I'm posting some pic's etc on a Yamaha Exup forum, (which is nearly dead) thought I might duplicate here?
I purchased this YB8 a while ago, and whilst it looks nice in the photos, I doubt it has ever had the fairing off, and been washed. I tend to get a bit carried away with my builds, but the up side is I know what I've got at the end.
Posted: Mon Sep 04, 2017 1:57 am Post subject: |
Here's what it looked like on the inside
So now for some cleaning... Shock needs a replacement as it was leaking and airless. I'll look at servicing it at a later date. I have a good spare kicking around so that will go in.
Posted: Tue Sep 05, 2017 12:49 am Post subject: |
Bodywork looks to be in good nic. I'd love to see some pics of the race bikes _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Tue Sep 05, 2017 2:03 am Post subject: |
Body work is quite good, the state of it underneath was a bit of a surprise!
With a bit of elbow grease not such a problem, though I feel as if I have spent a lot of time with my hands in cold water! However, everything is now looking like it should.
Unfortunately the bike took a hit in transit (high seas), and the rear sub-frame was toast, luckily I had a spare. The hammer is there just to motivate the parts!
Here's one of the race bikes,
And my golden child, you can see carby cross-member has been modified to take 41mm FCR's :
Admin Site Admin
Posted: Tue Oct 17, 2017 7:12 pm Post subject: |
Clean enough to eat your dinner off.
Carbs make much difference?
Katy |
Posted: Sun Oct 22, 2017 10:46 am Post subject: |
Clean is good!
Yep the 41mm FCR's will make a large difference, especially with ram air. Injection Throttle bodies are 38mm, though you can machine them to 39mm or a bit bigger.
Vroom vroomm!
(Edit: Talking throttle bodies because it is a Furano. though probably even more rwhp with a carb model.).
Posted: Mon Oct 23, 2017 2:21 am Post subject: |
Speaking of Bimotas... Check out this crazy rooster.
It's a roller I purchase off a mate. (it's a roller because I put a front end into it! hahaha.)
I'm just going to have to stop at some stage....
Stop what? lol.
Admin Site Admin
Posted: Mon Oct 23, 2017 6:39 pm Post subject: |
I have 40mm flat slides on my Bandit (just Mikunis). Gave a bit more peak power. But on the road not sure I would bother.
Clearance on the Dieci between the carbs and the fame is tiny. I have a spare set of carbs from an FZR1000 at the moment, and you have to grind off the small spigots on the float bowls for them to fit (As Bimota did!)
Katy |
Posted: Tue Oct 24, 2017 12:37 am Post subject: |
The gold Furano with the cutouts was a race bike. Hence the 41mm FCR's. I wouldn't bother using them for the road either Katy.
Interesting tip regarding the BSDT 38mm Carbs, I'll have to add that to my notes!
You have me worried now, as I was wanting to fit the next Bimota race bike build with the YB11 Bdsr 38mm carbs, and at some time respaced BDSR 41mm from the R1 which will give the performance of a 39mm FCR, with more power and no drivability problems.
I just fitted respaced Thunderace BDSR 38mm to my FZR1000 genesis race bike, I'll have to check float bowl clearance on the YB6 before I do.
Here's a pick of the FZR1000 with the BDSR 38mm carbs fitted. Not an easy fit up as I had to cut and reweld the race tank, and do various other jobs, airbox, inlet manifold widening, machine inlet rubbers, etc. These are old photo's, it is far further developed now.
The old carbs oem carbs on the 88 Genesis FZR1000 (same carbs as the Genesis powered YB6), are a Mikuni BDS 37mm. They are good reliable solid long wearing carbs, but 37mm and oval slide, so I would guess the equivalent of a 35mm round slide, so you can imagine how the YB11 carbs will improve power. (about 8-10 RWHP)
The EXUP Mikunis like on your YB10, were a chink in the amour for Yamaha. Not a good carb, prone to flogging out needles and emulsion tubes in few km's. The FZR750RR OW01 were fitted with a variant of this carb, and that cost yamaha WSK victory on this wonderful homologation bike. Shame!
The Mikuni BDSR 38mm fitted to the YB11 is the little brother of the R1 carb, and again an excellent carburetor, that offers good power and reliability. They also offer about 4 peak rwhp.
You will notice the bimota influences on the 88 FZR1000 build!
Cheers, Ralph. |
Posted: Tue Oct 24, 2017 6:51 am Post subject: |
WOW , I thought the gold frame was bright , but that body work is urm , Interesting !!!!!
Certainly wont get lost on the grid in those colours !! Are you having leathers made to match the 80's theme ?
The anodized frame must have been a bit of a trend for Bimota race bikes. I've seen another race YB8 with a red ( well actually pink now ) anodized frame and swing arm etc.
The road bike certainly seems a bit of Dr Jekyll and Mr Hide , nice on the outside but a monster underneath !!! |
Posted: Tue Oct 24, 2017 11:05 am Post subject: |
Hey...theres certainly nothing wrong with the 80's colour schemes....they went with that crazy era in time and certainly stand out...no shrinking Violets allowed in the 80's.....But then....why oh my was my DB2 painted up as per below when it was the 1990's?????????....Still tempted to get a pattern set of fairings made up for some spare bodywork in these colours....but then I'd need the oscom wheels in purple and yellow also.....
Love the fact that the chequer and yellow and purple colouring flicks from front to back dependant if on left or right...must have been a nightmare for a painter to create something in 2 halves....
Posted: Wed Oct 25, 2017 7:31 am Post subject: |
| 2bims , I remember playing the MCN 'spot the ball' competition to win that bike, and TBH I love that paint scheme. There was a race SB7 and a tesi in very similar paint. Obviously GK had the tesi but the sb7 has disappeared, was in Bonhams auctions a few years ago but missed it. |
Posted: Wed Oct 25, 2017 11:11 am Post subject: |
I did say checkout this crazy rooster?
Posted: Wed Oct 25, 2017 12:06 pm Post subject: |
| vort28 wrote: |
l
You must mean this puppy....didn't realise you had taken part in the competition...way back in 1994...even have a coy of the MCN with the comp on the back page...and the bike in full colour
Stafford 2012 was the auction for the SB7
Posted: Thu Nov 09, 2017 7:12 am Post subject: |
Love it! SB7 is on my list  |
