DB7 dash
Number2
PostPosted: Sat Oct 21, 2017 1:06 am    Post subject: DB7 dash Reply with quote
does anyone have one that works
Gavin944888
PostPosted: Sat Oct 21, 2017 12:04 pm    Post subject: Reply with quote
Number2
You can buy the KOSO unit but without the Bimota B printed on the face for approx 350-400 usd but if you want a O.E.M Bimota one....expect a long wait and nothing short of 600-700 dollars
I hope that this helps
They are available over here and in Germany....if you want want help give us a shout out
Regards
Gavin
Cagiva Elefant 999r engined
Number2
PostPosted: Sat Oct 21, 2017 1:21 pm    Post subject: Reply with quote
please if you can find one I will take it. I can change the faceplate
Number2
PostPosted: Sat Oct 21, 2017 1:24 pm    Post subject: Reply with quote
I found one locally
PostPosted: Sat Oct 21, 2017 2:12 pm    Post subject: Reply with quote
I think its the Koso RX2+ that you need......
Faces can be changed...but means pulling off the tacho needle...and they can be tricky to repaste back in position
https://www.digital-speedos.co.uk/gauges-c4/motorcycle-gauges-c27/time-clocks-c46/koso-m1
arsenic
PostPosted: Sat Oct 21, 2017 4:15 pm    Post subject: Reply with quote
I have my db8 dash if you want, really good state.
Number2
PostPosted: Sat Oct 21, 2017 6:49 pm    Post subject: Reply with quote
I found the KOSO dash you are referring to but was told it is different internally
PostPosted: Sat Oct 21, 2017 8:16 pm    Post subject: Reply with quote
No...not that I know of....same with Koso clocks for DB5 and DB6...Bimota use the same units...the only difference is the ones Bimota used were cheaper with less functions....Normally you have 6 or 7 illuminated colours you can choose from....with the Bimota version...only one....KOSO clocks can also perform other functions like fuel level sensor, or speed by GPS monitor....Bimota versions no....the Bimota versions are "locked" and you cant adjust settings for wheel size etc etc...An out of the box KOSO unit you set up yourself with the parameters you want to use.....Who is it that's telling you different??
Number2
PostPosted: Sat Oct 21, 2017 10:47 pm    Post subject: Reply with quote
Bob from Bimota Spirit. So if I buy one and plug it in it should work?
Number2
PostPosted: Tue Oct 24, 2017 6:49 pm    Post subject: Reply with quote
spoke with the guy at KOSO and their universal dash is not a plug n play. Wires have to be spliced
