Honda Bimota kit swinging arm
Mike Jennings
PostPosted: Mon Oct 23, 2017 12:38 pm    Post subject: Honda Bimota kit swinging arm Reply with quote
Hello,
looking for a Bimota accessory swinging arm to fit a '70s S.O.H.C. Honda CB750,
Cheers, MikeJ
PostPosted: Mon Oct 23, 2017 1:20 pm    Post subject: Reply with quote
Get Monty out on Safari...you'll be needing all eyes and ears to meet that task
Mike Jennings
PostPosted: Wed Oct 25, 2017 7:51 pm    Post subject: Reply with quote
Hello 2Bims,
good thinking.....maybe I could sell her to defray the costs, after all, she justs sits there and eats all day,
Cheers, MikeJ
P.S. Glad to see you decided to stay with the forum and hope all's well with you.
PostPosted: Mon Oct 30, 2017 10:56 pm    Post subject: Reply with quote
https://www.officine08.com/shop/frames-swingarms/swingarms
not cheap but....
Mike Jennings
PostPosted: Fri Nov 03, 2017 10:21 pm    Post subject: Reply with quote
Hello Welshlamb,
many thanks for the tip but I'm trying to find one a little cheaper if I can,
Cheers, MikeJ
PostPosted: Sat Nov 04, 2017 12:39 am    Post subject: Reply with quote
Mike Jennings wrote:
Hello Welshlamb,
Cheers, MikeJ
Bimota and 'cheap' are often found in the same sentence ..!! I have seen Z900 swinging arms turn up on Italian auction sites (ebay, Bakeca and Kijiji) but Honda??
Good luck with your search in any case
Mike Jennings
PostPosted: Wed Feb 14, 2018 11:36 am    Post subject: Swinging arm Reply with quote
Hello Welshlamb,
you're right, Honda swinging arms are hard to find but I've obtained a Z900 swinging arm which I've checked out and will fit with some finagling. It'll be about 3/4" longer than the Honda swinging arm but that probably won't cause a problem,
Ah well, onward and upward!
Cheers, MikeJ
