Sb6 front indicator light
Rdz35
PostPosted: Fri Oct 27, 2017 10:34 am    Post subject: Sb6 front indicator light Reply with quote
Hi, I'm looking for front rh side indicator light for my SB6.
I'm not sure which other bike has maybe similar model? Any advice?
PostPosted: Fri Oct 27, 2017 1:04 pm    Post subject: Reply with quote
Ducati 750/900SSie, Ducati 748, 916, 996,998...all up to 2000 year....plenty of original new or patent copies on ebay
Rdz35
PostPosted: Fri Oct 27, 2017 9:05 pm    Post subject: Reply with quote
2bims, thank you!
PostPosted: Sat Oct 28, 2017 4:29 am    Post subject: Reply with quote
Buell also used them.
You can get clear lens off ebay there not so easy to fit because the screw hole is a bit tight / short and the locating tab breaks
Rdz35
PostPosted: Sat Oct 28, 2017 10:53 am    Post subject: Reply with quote
Ok, good to know. Quick ebay check and both types are available.
PostPosted: Sat Oct 28, 2017 4:13 pm    Post subject: Reply with quote
You can fit later styles too as long as they have the same mounting
