SB8R Tail piece mounting rubbers
neil
PostPosted: Thu Feb 15, 2018 3:54 am    Post subject: SB8R Tail piece mounting rubbers Reply with quote
Does anyone have a source for these? They’re the top hat shape ones under the Allen key on seaf unit.
Plus the lower fairing mounting rubber grommets? They’re getting a little perished.
I’ve tried Bimota classic parts and graf-de but neither has got back to me. Part numbers below.
I was also looking for a rearset guard (LH) from the RS rearsets as mine has a small crack....
1. QTY=3 Part No. 214000055 - passacavo (seatunit rubber), TAV Number - 12
2. QTY=2 Part No. 212000016 - silentblock (fairing lower rubber), TAV Number - 34A
3. QTY=1 Part No. 505170620 - protezione (peg guard)*, TAV Number 27A
*I have rearsets from the RS model, so I’m not sure if this is the correct part?
Any help appreciated!
Thanks
Neil
PostPosted: Thu Feb 15, 2018 12:14 pm    Post subject: Reply with quote
Rubber wiring grommets are what you may be after....many sizes...buy an assorted box...motor factor suppliers, etc....
https://www.ebay.co.uk/sch/i.html?_odkw=silent+block+bushes&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR12.TRC2.A0.H0.Xrubber+grommets.TRS0&_nkw=rubber+grommets&_sacat=0
Paulo girotti of BimotaClassicParts responds quicker if you message him via his Facebook account rather than emails to his website....
wdm
PostPosted: Sat Mar 03, 2018 9:01 pm    Post subject: Reply with quote
For Part No. 214000055 - passacavo (seatunit rubber), TAV Number - 12
I used NAPA Part Number NOE 7701306
Rubber Grommet Dorman Products Inc 7/8 I.D. in.
https://www.napaonline.com/en/p/NDP7701306
Not an exact fit but pretty close and definitely works. I assume the original is metric.
HTH - Whit
neil
PostPosted: Tue Mar 13, 2018 7:44 pm    Post subject: Reply with quote
Thanks Whit & 2Bims, they worked a treat. Hadn't actually removed one to check what it was, hadn't thought it was a grommet.
All sorted now.
Neil
