Rdz35
Posted: Fri Oct 27, 2017 10:34 am Post subject: Sb6 front indicator light |
Hi, I'm looking for front rh side indicator light for my SB6.
I'm not sure which other bike has maybe similar model? Any advice? |
Posted: Fri Oct 27, 2017 1:04 pm Post subject: |
| Ducati 750/900SSie, Ducati 748, 916, 996,998...all up to 2000 year....plenty of original new or patent copies on ebay |
Rdz35
Posted: Fri Oct 27, 2017 9:05 pm Post subject: |
| 2bims, thank you! |
Posted: Sat Oct 28, 2017 4:29 am Post subject: |
Buell also used them.
You can get clear lens off ebay there not so easy to fit because the screw hole is a bit tight / short and the locating tab breaks _________________ Don't read everything you believe |
Rdz35
Posted: Sat Oct 28, 2017 10:53 am Post subject: |
| Ok, good to know. Quick ebay check and both types are available. |
Posted: Sat Oct 28, 2017 4:13 pm Post subject: |
You can fit later styles too as long as they have the same mounting _________________ Don't read everything you believe |
