Brake Pad question for the old school Brembo F08 Calipers
rpo83
PostPosted: Sat Dec 30, 2017 5:57 am    Post subject: Brake Pad question for the old school Brembo F08 Calipers Reply with quote
Hi All,
as most of the early flavours of Bimotas, shared the same or similar Brembo calipers, i was wondering if anyone could make some recommendations for brake pads?
I'm about to rebuild the calipers and fit new master cylinders and S/Steel brake lines, so it's time for new pads, what works, doesn't work, i'd rather choose a pad that will be kind to the discs if there is one.
Can anyone also tell me the part # for the YB5 rear caliper? The only reference i have found is 20.2742.30 but i can't find any reference to it, i may as well rebuild the rear whilst i'm at it.. The fronts are Goldline F08's, but the rear is black and a different model...
Steve
1988 YB5
1995 SB6
PostPosted: Sat Dec 30, 2017 12:19 pm    Post subject: Reply with quote
FO8's or PO8's????....These guys sell brembo spares....youre right...IMHO..to go for softer pads to preserve discs...pads are cheaper and easily available compared to the discs...as you have high iron content discs front and rear...steer clear of red plate backed brembo pads...these are sintered race pads and will eat your discs alive....I always try to get brembo original....
https://www.mdinaitalia.co.uk/search/for/brembo/page/1/
These guys I've also used...selling PO8 rebuild kits....bolts and seals...to give you an idea of price....
http://www.ducati-kaemna.de/catalogsearch/result/index/?p=2&q=brembo
PostPosted: Sat Dec 30, 2017 2:31 pm    Post subject: Reply with quote
Theres also Bevel Heaven who sell kits and brake pads....basically you want Brembo pads and not Sintered or organic or race...
https://store.bevelheaven.com/index.php?p=catalog&mode=manufacturer&parent=0&mid=4&search_in=all&search_str=&pg=2
PostPosted: Sat Dec 30, 2017 9:49 pm    Post subject: Reply with quote
I get my Brembo pads locally from Gowanlochs. He knows which pads are for which disc material so that helps.
rpo83
PostPosted: Sat Dec 30, 2017 11:11 pm    Post subject: Reply with quote
Hi Steve,
i got these codes from this web site http://www.thisoldtractor.com/brembo_brembo_brake_and_clutch_cross_reference_for_bimota_motorcycles.html
From searching those #'s i found a cross reference to F08, but rumaging around some Ducati pages i saw P08's mentioned for Ducati... If you have any further light you can shed on the subject it would be appreciated.. I believe the F08 and P08 share the same piston diameter, other than that i don't know the difference between them
Any idea on the rear caliper??
Steve
1988 YB5
1995 SB6
rpo83
PostPosted: Sat Dec 30, 2017 11:13 pm    Post subject: Reply with quote
Hi Lech,
which Gowanlochs??? The store that uses his name, or the man himself??
Steve
1988 YB5
1995 SB6
PostPosted: Sun Dec 31, 2017 11:28 pm    Post subject: Reply with quote
From the shop, run by Mike Soderland:
https://ducati-gowanloch.com/product-category/brakes/brake-pads/brembo-brake-pads/
v-pilot
PostPosted: Mon Jan 01, 2018 6:56 am    Post subject: Reply with quote
The older Italian stuff I've had used the F05 caliper on the rear. I had good results from the Ferodo's
02 aprilia RSVR Mille, 02 aprilia SL1000 Falco
96 Ducati 900 SS/SP
78 Moto Guzzi V50
68 benelli 250 65 Ducati 250
PaulDB2
PostPosted: Mon Jan 01, 2018 11:25 am    Post subject: Reply with quote
I believe the rear caliper is a Brembo P32 variant, same as fitted to the DB1. Rebuild kits should be easily available. Lovely looking YB5 Cool
Bimota DB1, Bimota YB6 Exup, Bimota YB9 SR, Ducati NCR Replica, 1997 Ducati 900SS, Honda CR750 project
rpo83
PostPosted: Mon Jan 01, 2018 12:51 pm    Post subject: Reply with quote
Thanks Guys,
Paul, i think you are correct... Thanks.
Steve
1988 YB5
1995 SB6
