JBTrout
Posted: Tue Jan 30, 2018 4:54 pm Post subject: SB6 Wiring Harness |
HI All!
Can anyone tell me where the two -what look like ground- wires with the ring terminal ends connect to the bike? Both wires emerg from the harness near the water temperature sensor and switch. One wire is about 4 inches long and the other is about 12 inches long. I took a picture but can't figure out how to upload it. Thank you in advance,
Cheers, Neil
I was previously logged on as miriman but couldn't get logged on again. I'm taken a break and I am now determinded to get this thing together. |
Posted: Tue Jan 30, 2018 6:40 pm Post subject: |
What colour are they ? _________________ Don't read everything you believe |
JBTrout
Posted: Tue Jan 30, 2018 7:18 pm Post subject: |
The wires are black. They emerg from the harness at the same point. |
JBTrout
Posted: Tue Jan 30, 2018 10:47 pm Post subject: |
Hmmm :sucks teeth: _________________ Don't read everything you believe |
JBTrout
Posted: Tue Jan 30, 2018 11:04 pm Post subject: |
Would they go to the coils? |
Posted: Wed Jan 31, 2018 11:34 pm Post subject: |
The problem with the sb6 wiring is the lack of a reliable diagram and you can use the Suzuki one because because bimota changed the colours
I'll try to get to the garage over the weekend.
In the mean time get yourself an assorted load of small zip ties (Maplin do a bucket of them https://www.maplin.co.uk/p/cable-tie-kit-100mm-1000-pack-nl18u ) and mark the connections _________________ Don't read everything you believe |
