DB9
mickgrim
PostPosted: Sat Feb 10, 2018 10:03 pm    Post subject: DB9 Reply with quote
I keep emailing the factory for a bolt part number 507099010 M10x1.25
get reply not open till 10 31 2017 can anyone help thanks.
SB8R owner and loved most of it.
Now DB9 still bonding
PostPosted: Sun Feb 11, 2018 1:12 am    Post subject: Reply with quote
Is it a "special" bolt...what bike is it for...a DB9?
Its been around a year since the factory shut down operations so I wouldn't be holding ones breath........
Normally the spare parts manuals also give you the length of the bolt....you already have the size and thread pitch so most bolt suppliers could help
arsenic
PostPosted: Sun Feb 11, 2018 11:12 am    Post subject: Reply with quote
Where the bolt is located ? If itís on the engine, just contact Ducati...
DB8SP / Brutale 1090RR / 530EXC supermoto
PostPosted: Sun Feb 11, 2018 11:34 am    Post subject: Reply with quote
I'm guessing...by the size and pitch , that its a front disc caliper retaining bolt...allen headed.....THey have shallow recesses and can "round" quite easily if the socket isn't securely fitted......Ducati front disc caliper bolts will fit although the heads aren't so nicely finished as on the Bimotas...but they do fit...and have a deeper socket recess for torqueing up...from memory they are slightly shorter in length but still have sufficient length for torqueing up properly
mickgrim
PostPosted: Sun Feb 11, 2018 2:21 pm    Post subject: Reply with quote
It's a special bolt looks the same on all the DB series holds the swingarm plate and the alloy plate to the frame 16 of them on the bike .
The catalogue part number is 507099010.
Thanks for help and it's a DB9
arsenic
PostPosted: Sun Feb 11, 2018 2:35 pm    Post subject: Reply with quote
Try with Motocorse Japan then, send them a mail.
Gavin944888
PostPosted: Sun Feb 11, 2018 8:32 pm    Post subject: Reply with quote
Hello".......do not contact the factory...It is dead
The bolt you require should be ex stock on the Bimota Classic Parts website
Failling this ...it can be got (maybe) from The German Bimota parts company
DRT something".....they advertise on eBay de
Hope this helps.......just make sure you have the correct part number ...this cuts through all languages
Gavin
Cagiva Elefant 999r engined
BIMOTA DB7-11 VLX MULE (project build with no end)
mickgrim
PostPosted: Sun Feb 11, 2018 10:07 pm    Post subject: Reply with quote
Thanks for the info will email them Monday.
Didn't know the factory had died again do you know why.
Was going to visit them again in June with a list I can forget that now.
Gavin944888
PostPosted: Mon Feb 12, 2018 3:36 pm    Post subject: Reply with quote
Mickgrim,
YES............they are dead and as for WHY ....the answer is that the management team were neither capable of management or a team.
Strip an asset and move everything of value to a self storage depot or Switzerland.
Please do visit....but even the sign has been taken down from the building.
Sad and very annoying
regards
Gavin
