mibota
Posted: Wed Jun 02, 2010 8:02 pm Post subject: New Member - First Question - DB2 Steering Damper |
Hello to all you discerning top draw motorcyclists , i have been a lurker here for some time and have a DB2; at present it is not fitted with a steering damper - Q. Is it likely to be the Tank Slapper from Hell the minute i ride it without said damper, or is it a superfluous item that i can leave off in safety?? the bike has a few other issues to sort before i can ride it and as i am not a test pilot i would be grateful for any advice received.
I suspect from the steering geometry that the damper is a 'must have' if so, could anyone tell me what make / model is standard Bimota for the DB2 and a supplier, i would also need the mounting brackets - any suggestions on a source please? thanks, J |
Posted: Wed Jun 02, 2010 10:06 pm Post subject: |
Welcome to the forum
Depends how you ride as to weather you even need a steering damper.
My SB6R hasn't got one any longer, I ride it quite hard in the twisty bits and I'm still here.
As long as you ride it sensibly, you might save money by not having one |
Posted: Wed Jun 02, 2010 11:05 pm Post subject: |
my DB2 has the fork leg mounting bracket for a damper to attach to, but no damper.
ridden "enthusiastically" it can get a bit flighty but so far I've just ridden through it - shades of my wayward TL1000S - but I am on the lookout for a damper! |
Posted: Thu Jun 03, 2010 10:58 am Post subject: |
I would spend the money on reworking and setting up your suspension before using a damper to mask any issues you may have. Only way forward! _________________ Pomps
mibota
Posted: Thu Jun 03, 2010 12:51 pm Post subject: |
Thanks for the advice and the welcome; does any DB2 owner reading this have a damper fitted? if not i will leave it off. Not so sure i like the idea of it being a bit 'flighty', i suffered a tank slapper on a race bike once (broken damper mount) and i am not in a hurry to repeat the experience.
In the bikes 'history' the suspension has been 're-worked' & 'set-up' by MAXTON; as i recall if i mentioned that in the paddock i would have heard a lot of sniggers! however i will assume it was set up reasonably well and the damper was junked as a result - lets hope so!!
Any more thoughts please let me know. Cheers J |
Posted: Sat Jun 05, 2010 11:24 am Post subject: |
The fact that the bike was set up prior to you is not an advantage... unless you know the previous owners weight, road type, track setp and his rider style? Was he a late braker or quick on the gas prior to turn in, mid corner or just a point and squirt merchant. Before anything else make sure you have some sag front and back. Take it for a spin on a set route of different types of bends and tarmac conditions and let me know how it felt? _________________ Pomps
mibota
Posted: Sat Jun 05, 2010 11:44 am Post subject: |
Thanks Pompey, i do have some experience in setting up bikes but am no longer as serious or focussed, however as you realise it doesn't take much to induce a tank slapper focussed or not which is my main concern.
I will let you know how i get on. Does any one know what make the OE damper was? Ohlin, Paoli? Thanks again. J |
kb11110cc
Joined: 03 Dec 2009 Posts: 48 Location: Southampton area
Posted: Mon Jun 14, 2010 12:30 pm Post subject: |
Hey
If you still want a steering damper for your DB2 then there is one for sale in the USA
here is the link number on ebay
280518540380
KB1 |
mibota
Posted: Tue Jun 15, 2010 7:29 pm Post subject: |
Thanks to all for the advice and the lead on the USA ebay damper. I rode the bike on Sunday around my local A & B roads which have examples of every combination of bend / hill / straight you can imagine and i have to say it behaved impecably, didn't shake it's head once even though i got the front wheel very light / airborne over a couple of crests; although i was scrubbing in a pair of tyres and being relatively careful i am confident enough in the bike to forget the steering damper issue.
Should these DB2 Paoli forks have any form of adjustment on them other than changing the weight of the oil or replacing the springs ie. adjustable tops to the forks for damping?? thanks J |
