WANTED YB8 PARTS
MWR
PostPosted: Thu Mar 01, 2018 4:14 am    Post subject: WANTED YB8 PARTS Reply with quote
Very Happy looking for the following for a ; YB8- 1991 -FZR powered;
engine mount adjusters x 2
seat mount plugs & bolts x 2 -rear
tank cover bolt(s) front
petrol tank
fairing set
front guard
clock set
I have a new YB8 from Japan with no motor and the following has been robbed off the bike
murraywestracing@gmail.com
YB8E
HARRIS F1
ZXR750
RZ390
RS250 GP HONDA
DUCATI749R
APRILLIA SL ALUMININO
PostPosted: Thu Mar 01, 2018 8:58 am    Post subject: Reply with quote
Firstly...welcome to the Forum and the World of Bimota Ownership.....And secondly....BEst of luck.....your task should not be underestimated....Did you not fancy an easier task? Like cycling to Mars??? Which YB8 is it? The Evo or the Exup??....Frame number would help
You can download and print off the exploded Spare PArts diagrams from this lovely mans website in GErmany...that help in putting bikes back together...and it has the parts numbers and pictures of the bits you'll need
http://www.bimota-parts.de/en/teileshop.html
If you put an enquiry to him for parts...even if he hasn't got them listed...he will assist where he can...He only speaks GErman so write in simple English and use a translate tool to convert to GErman for him
HEre is the YB8 Evo spare parts catalogue
http://www.bimota-parts.de/images/PDF/YB8%20Evo.pdf
You can also try this place:-Go to this fellow...again in GErmany...Armin Schneider is his name....click on "Ersatzteile"////3rd item on links on the left side...scroll down and he has list of bikes he has parts for.....then in the middle menu click on the 3 No. YB8's he has listed YB8 Exup, YB8E and YB8 IE...(Yup 3 different models for the YB8!!)...Armin lists the parts he has by part number...hence you will need the spare parts brochures....
http://bimota-teile.de/Bimota/index.html
And last but not least...but maybe "most expensive" theres Paulo Girotti in Itlay of Bimota Classic PArts.....Who reads and writes and speaks english...he also has the spare parts manuals but doesnt allow them to be downloaded or printed
Scroll to the very bottom of this link....he has the 3 different spare parts brochures to be viewed for each of the 3 No. YB8 models....He is best contacted via his Facebook contact for BimotaClassicParts....and also ask to be his "personal" friend under his Paolo Girotti Faebook page...as he replies to that 24/7....You will have to get used to "new technology" to revive "old technology......Find the parts you need and then post up a list also so that I and others can search more easily for you...Oh and photos...WE need photos..........
http://www.bimotaclassicparts.com/en/content/72-manuali-bimota
https://www.facebook.com/groups/1573525059530286/
That lot should give you something to chew on............
Laughing
PostPosted: Thu Mar 01, 2018 9:13 am    Post subject: Reply with quote
Also contact Lech Budniak...he lives in Oz and has a race YB8...maybe he has spare bits or could make a fairing for you from his???
https://www.facebook.com/groups/1606021379409823/?fref=nf
:Look at the picture here...BCP seems to have new YB8 Evo fairings hanging up in his shop....so be sure to ask him for seat/tank units....and tank also
http://www.bimotaclassicparts.com/en/content/4-chi-siamo
PostPosted: Thu Mar 01, 2018 9:29 am    Post subject: Reply with quote
Describe the wheels and the front forks and we can identify the Model....Upside down forks or right way up...if RWU are they Paioli or Marzocchi M1R forks???
PostPosted: Thu Mar 01, 2018 3:26 pm    Post subject: YB8 Reply with quote
There are people offering aftermarket 8e fairings, but this will not fit onto an 8, unless you also fit an 8e headlight bracket.
8 front mudguards are readily available on the bay.
Petrol tank is most likely only going to come from a source such as those recommended by 2 Bims and will be expensive.
Bear in mind that the thermostat and associated plumbing is quite different on an 8 compared to an FZR 1000.
If we haven't talked you out of it - good luck!
PostPosted: Thu Mar 01, 2018 6:02 pm    Post subject: Reply with quote
Yup....YB8 front mudguards on ebay Italy/Germany...repro in white or genuine in red...if he has RWU forks....and the alloy plate fork brace
http://www.ebay.it/itm/WR23-Bimota-YB-8-Schutzblech-Vorne-GFK-Radabdeckung-Fender-Kotflugel-Verkleidung/263349755470?hash=item3d50de5e4e:g:sw4AAOSw8UZaH~pD
https://www.ebay.it/itm/Bimota-YB8-Kotflugel-Mudguard-rot-red-original-500970400-RARITAT/372006784822?hash=item569d550f36:g:~x8AAOSwo4pYfj1Z
Even swingarms:-
https://www.ebay.it/itm/Bimota-YB8E-Schwinge-original-503062011-RARITAT/262792131130?hash=item3d2fa1b23a:g:SkkAAOSw9GhYbMrn
Heres a list if stuff currently on another website in Italy for YB8 bits...if you ever get a petrol tank, you'll need a filler cap for the dummy tank coverHeadlights also on here
https://www.subito.it/annunci-italia/vendita/usato/?q=bimota+yb8
It would be cheaper to just buy this one...he also has a complete set of spare bodywork as noted...hence the different colour schemes in the pictures... https://www.subito.it/moto-e-scooter/bimota-altro-modello-1992-padova-230849156.htm
MWR
PostPosted: Wed May 09, 2018 1:31 am    Post subject: Reply with quote
thanks guys great help, seems there is parts around the world, didn't know the difference between YB8 and YB8Evo??
mine is labelled YB8E
forks are ;
RWU Paioli's?
front guard is doing my head in, some are c/f mounted off the calliper mount bolts and others from the brace???[/img]
YB8E
HARRIS F1
ZXR750
RZ390
RS250 GP HONDA
DUCATI749R
PostPosted: Wed May 09, 2018 9:02 am    Post subject: YB8E Reply with quote
With Paioli forks, you have a YB8E and therefore need the carbon mudguard that mounts on the caliper bolts.
PostPosted: Wed Jun 20, 2018 8:43 am    Post subject: Reply with quote
I've never seen a fabricated YB8 swingarm with YB11 style axle adjusters?
Fairings, in grp and carbon-kevlar
https://www.motoforzafairings.com/complete-set-2-pieces-street-bimota-yb8-yb8-furano-91-93
