Yb9 seat , tank unite removal
Alan simons
PostPosted: Sun Mar 25, 2018 1:11 pm    Post subject: Yb9 seat , tank unite removal Reply with quote
How to remove seat ,tank unite yb9 ,have removed fixings to fairin and rear , still feels fixed ,first time lv tried do not want to force any help .
PostPosted: Sun Mar 25, 2018 9:10 pm    Post subject: Reply with quote
Have you removed the fuel cap???...Page 35 on here may help you...don't forget to disconnect the electrical connecter under the fairing for the rear light/indicators...and don't forget the fuel cap actually locks into the tank underneath....the seat/tank cover being just that...a cover for the tank...so it stops the cover being removed if you don't remove it
https://www.sfogliami.it/fl/117652/hpv5v2kdltkle5p6um3op73orusuquh3#page/94
I can send you another link if you wish to download the spare parts exploded manual for free if you wish...as BCP's site doesn't allow this....you can merely from from there
PostPosted: Mon Mar 26, 2018 10:05 am    Post subject: Reply with quote
I loosen the front fairing and pull it forward to clear the carbon air tubes and fairing where it covers the frame. This requires removing the mirrors and mirror brackets, etc. As 2Bims mentioned don't forget to take the filler cap off.
Alan simons
PostPosted: Tue Mar 27, 2018 7:53 pm    Post subject: Reply with quote
Seat unite and fairing off thanks for help and info
PostPosted: Tue Mar 27, 2018 9:43 pm    Post subject: Reply with quote
Go on tell us....what was keeping it from being removed...theres no shame on here....its just called "education" and all part of the learning process with Bimotas and the lack of dealers/manufacturer etc etc...
Alan simons
PostPosted: Sun Apr 01, 2018 6:00 pm    Post subject: Reply with quote
Yes once I moved fairing foreword the seat, tank came free , new prob engine runs with choke on cuts out when off , found fuel pump disconnected , connected up only to pump fuel every were .l no cards need to be cleaned but dose pump need to be connected ? Thanks Alan
