Posted: Mon Aug 10, 2020 4:07 pm Post subject: |
#13 is the all in one dust cover and nut , it works great
and where did you get the Öhlins ?
Cheers Trev |
steff_dk
Posted: Mon Aug 10, 2020 5:57 pm Post subject: |
trev45 wrote: |
Cheers Trev |
Thank you Trev - so the dust cover is threaded on the inside then?
Got the rear shock from wrs.it and the forks from a user on triumph675.net |
Posted: Mon Aug 10, 2020 11:48 pm Post subject: |
It is threaded and who is WRS and do you have a contact ?
Cheers Trev |
Weed
steff_dk
Posted: Tue Aug 11, 2020 7:13 pm Post subject: |
trev45 wrote: |
Cheers Trev |
It is the company that Weed provided a link for but their prices are better in their eBay listings.
Search for "ohlins bimota strada" ...
-> https://www.ebay.com/itm/OHLINS-SHOCK-BIMOTA-500-STRADA/401640499628 |
Posted: Tue Aug 11, 2020 11:20 pm Post subject: |
Are you sure its not the Ducati 500 strata shock what is the length eye to eye ?
Brought one years ago and got court out like this ?
Different part numbers ?
Cheers Trev
steff_dk
Posted: Tue Aug 11, 2020 11:51 pm Post subject: |
trev45 wrote: |
Cheers Trev |
Should be the right one. Part number is correct anyway ...
https://www.ohlins.com/product-item/61165/ |
Posted: Wed Aug 12, 2020 10:59 pm Post subject: |
That's great news cheaper then the other one I found in France
Have you started to build it yet , up on the wheels ?
Cheers Trev |
Posted: Wed Aug 12, 2020 11:09 pm Post subject: |
Maybe we need one each Weed ?
Cheers Trev |
Weed
Posted: Thu Aug 13, 2020 12:52 am Post subject: |
trev45 wrote: |
Cheers Trev |
I think so mate |
steff_dk
Posted: Thu May 06, 2021 2:11 pm Post subject: |
So I was having some issues finding a 20mm rear axle that was long enough for the SB8 swing arm.
Finally found that a Honda Firestorm axle should be 20mm diameter and the same length as the SB8 axle. That turned out to be almost correct:)
Of course the threading wasn't the same either.
So with some help from my contact that milled my yokes I had the left chain tensioner opened up a bit, and had a special hex-nut-tube-whatchamacallit made.
And so, now I can fit the Triumph Daytona 675 rear wheel in my frame.
Next up will be to see if Mr. Fiedler will take pity in my inabilities and assemble the pile of parts I have as it should complete a rolling chassis by now. Just waiting for travel restrictions to be lifted. |
Posted: Fri May 07, 2021 12:00 am Post subject: |
Nice solution and a nice job done. I’d have a nice plug of some some put in the unused portion of the thread in the nut..... otherwise you’ll always have well meaning onlookers telling you that your axle is loose and your wheel is going to fall off.
Maybe a nice bespoke machined aluminium plug with the b symbol milled into it _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
steff_dk
Posted: Fri May 07, 2021 2:26 pm Post subject: |
brian wrote: |
I’d have a nice plug of some some put in the unused portion of the thread in the nut..... otherwise you’ll always have well meaning onlookers telling you that your axle is loose and your wheel is going to fall off. |
Yeah - now that you mention it I see your point. I may end up going the easy route and just remove the unused thread on a lathe. |
Posted: Tue May 11, 2021 11:41 am Post subject: |
I have started a project with CBR600 front end and VFR400 single sided swinger. |
