SB6, 6R and 7 Shock Reservoir Bracket
Goto page Previous  1, 2
PostPosted: Thu May 10, 2018 11:09 am    Post subject: Reply with quote
Evilchicken0 wrote:
So far drawn a bit of a blank with a bracket coming in at 100+
No worries Boris, I probably don't really need one for the SB6 anyway as my stock clamp is still in good nic.
PostPosted: Thu May 10, 2018 11:10 am    Post subject: Reply with quote
And I'll see what I can do with the Chinese bracket for the DB4
PostPosted: Thu May 10, 2018 11:17 am    Post subject: Reply with quote
I've ordered a pair of 52mm P-Clips from the bay ... just to have a look
PostPosted: Fri May 11, 2018 11:04 am    Post subject: Reply with quote
Are they the plastic lined ones similar to the stock one?
PostPosted: Fri May 11, 2018 11:55 am    Post subject: Reply with quote
Plastic lined 52mm dia stainless. Like this https://www.ebay.co.uk/itm/262483598137?_sp=p2488212.m41214.l9765&_trkparms=itemid%3A262483598137
Hopefully the diameter will be ok or I'll be able to persuade it to fit. I bought 2 with a thought that they'll be narrow enough to sit side by side.
PostPosted: Fri May 11, 2018 5:09 pm    Post subject: Reply with quote
Jeeso...I didn't know they did P-clips that big....and should certainly arrive in the post quicker than ching chong versions sailing across the seas.....
PostPosted: Sun May 13, 2018 10:06 am    Post subject: Reply with quote
I went from looking fork clamps but then wonderred about p-clips, i saw some large ones used on a building site.
The 52mm is stainless theres a 53mm but its steel.
I tried to put the fairing back on with bracket on the wrong way and couldnt get it to join at the bottom. Just shows how small the tollerances are
Page 2 of 2
