Lights out..............
PostPosted: Sun May 20, 2018 12:17 am    Post subject: Reply with quote
Bad earth!
PostPosted: Sun May 20, 2018 9:20 am    Post subject: Reply with quote
Bad earth!
but the earth to the bulb holder is OK for the tail lamp to function OK - it earth's to the bulb body - so the stop lamp should work too.
PostPosted: Sun May 20, 2018 12:44 pm    Post subject: Reply with quote
GeeKay wrote:
Bad earth!
Electrics can be fickle things. Hard without looking at it. The symptoms in your original post point to bad earth to me. I'd double check the tail unit earth all the way back. Check all the connections and earth points on the frame etc too
PostPosted: Sun May 20, 2018 11:35 pm    Post subject: Reply with quote
Is the bulb in the right way round.
PostPosted: Mon May 21, 2018 10:21 am    Post subject: Reply with quote
offset pins so only fits one way.
PostPosted: Mon May 21, 2018 10:31 am    Post subject: Reply with quote
Is your head on the right way around???..... Laughing
But seriously...before you removed the loom and spliced and cut and remade...did either of the front or rear brake switches work?
Admin
Site Admin
PostPosted: Mon May 21, 2018 10:59 am    Post subject: Reply with quote
While the bulb holder only holds a bulb one one (well, without more force than advisable!), the spade connectors on the back can go on either way.
The brake light bulb draws ~4 times the current of the tail light bulb.
I would be tempted to run a supplementary earth to the rear light to see if that changes things.
As an aside, you are getting 11.36v at the tail light. What is the voltage over the battery?
Katy
PostPosted: Mon May 21, 2018 1:56 pm    Post subject: Reply with quote
All the best Katy
That was going to be my second point, rig a temporary earth from the the bolt holding the rubber generator cover to the lamp and see how that affects things
PostPosted: Mon May 21, 2018 4:20 pm    Post subject: 6R rear light Reply with quote
Check that the wires going into the ignition switch have not been chafed.
PostPosted: Tue May 22, 2018 2:10 pm    Post subject: Reply with quote
so, as suggested, I ran a temporary earth straight from the battery earth terminal,so.......................
and connected it direct to the tail lamp unit. Tested with side lamp wire - both filaments could be illuminated - tried with wire from brake switches - nothing - zilch.
I then connected another "jumper" wire to the live feed (red wire) to the rear brake switch and connected it to the stop lamp filament of the bulb, with the original (loom) earth wire attached, and it illuminated. So to me, the problem lies with the feed to the switches.
Next step is to jury-rig a live feed, direct from the battery, to the rear brake switch and see if that works.
All this for a bloody MOT - grrrrrrrrrrrrrrrrrrrr Evil or Very Mad
PostPosted: Tue May 22, 2018 5:41 pm    Post subject: Reply with quote
Sounds like you need a New MOT garage to get your bikes tested.....The most rigorous check I receive is whether I've brought biscuits to go with his coffee.....Although a functioning brake light is quite a nice "addition" to a motobike
PostPosted: Tue May 22, 2018 5:56 pm    Post subject: Reply with quote
Cheer up - my Six has roughly the same problem except the rear indicators don't work either. At least you didn't blow the main fuse Wink
Admin
Site Admin
PostPosted: Tue May 22, 2018 6:24 pm    Post subject: Reply with quote
Hiya
Silly question I know, but do you have a wiring diagram you can post?
Katy
PostPosted: Tue May 22, 2018 8:44 pm    Post subject: Reply with quote
Ta Da.............................!
Very Happy
PostPosted: Tue May 22, 2018 8:46 pm    Post subject: Reply with quote
Admin wrote:
Hiya
Katy
No I haven't, Katy.
Page 2 of 3
