New...
daward
PostPosted: Thu Jun 07, 2018 2:59 pm    Post subject: Reply with quote
Yes the little Mondial OHC is a fine thing - it got me all the way round the Motogiro d’Italia in 2014.
Good spot on the Jota - nice hydraulic clutch with a pleasant action and no propensity for broken cables! I tend to go for long distance usability over originality Very Happy
PostPosted: Thu Jun 07, 2018 4:21 pm    Post subject: Reply with quote
Whatever you do...dont mention the Moto giro d'italia...Oops....I've just done it now also.....
YB10 does look in fine fettle...even disc bolts still with their Bimota gold lustre....
Rear indicators not original...but I'll save you the time and effort....Originals not around no more...and no-one has ever seen any of them on a bike OTHER than another Bimota....
ruffef
PostPosted: Thu Jun 07, 2018 9:16 pm    Post subject: Reply with quote
daward- where in surrey are you? I went to WSSC to look at that bike, then got tempted by a YB6, which i dallied on, so missed out and ended up with a YB8
and bizarrely i had to introduce the YB8 to its family, which also included an '81 180 Jota.
small world
still looking....
PostPosted: Thu Jun 07, 2018 9:27 pm    Post subject: Reply with quote
That looks to be in top nick. Very nice buy!
I've found the standard brakes to be perfectly suitable for race track use, whether it be with the stock Brembo cast iron discs, or with the R1 wheels and discs and accompanying pads.
I've bought bikes where the brakes don't work very well due to the cleaning products used. The pads and discs are coated with the slippery product. I would suggest that the first thing to get the brakes working would be to fit some new genuine Brembo pads. Clean the discs with brake cleaner but they should clean up by themselves pretty quickly.
Enjoy the ride!
daward
PostPosted: Thu Jun 07, 2018 10:15 pm    Post subject: Reply with quote
Cheers guys! Just down the road from Brooklands.
Started to work through some things this evening - the top bodywork comes off nice and easy...
Surprised by how quiet the bike is - must be a well-baffled can. Is the exhaust system stock FZR (apart from the end can) and has anyone done anything different?
David
Admin
Site Admin
PostPosted: Sun Jun 10, 2018 8:46 pm    Post subject: Reply with quote
I have a Brembo master cylinder from an Aprilia on mine. Gives the brakes far more feel. Ultimate power possibly not better but I far prefer it.
For the connector under the seat i have used a super seal connector. Waterproof so better in that rather exposed location, and also only goes in one way unlike the original connector.
Performance wise, on Woodbridge airfield with the mirrors removed and a bit of a tail wind mine managed 177mph with me on it.
I have a new rear hugger on order at the moment. The original wasn’t great and I have tried repairing it a few times. Ordered a carbon fibre one. Can go on unpainted and I will see how I like it.
Check if the reserve switch works.
Katy
daward
PostPosted: Mon Jun 11, 2018 8:04 am    Post subject: Reply with quote
Thanks Katy - nice top speed!
Was planning on a little re-wiring under the rear. Not checked reserve yet, but had noted the previous comments on the switch. My hugger has some small cracks round one of the front mounting points but is otherwise good...
Any chance you could put up a pic of your Aprilia master cylinder?
Been enjoying it too much over the weekend to do much other than fit a new number plate! About 300km now done just to get a feel for it, so now to start working through a few things over the next few weeks. New rubber for a start...
PostPosted: Mon Jun 11, 2018 9:22 am    Post subject: Reply with quote
Pull the sprocket cush drive assembly off the rear wheel if going for new rubber...and check the integrity of the button allen headed cush drive bolts that screw into the rear hub.....They've been known to snap their heads off as they were Undersized originally......only ever seen it on the Oscom Bimota branded wheels like yours has...but only ever seen it on the DB2 happen....which is fitted with the same wheels.....and check the cush drive rubbers aren't perished......and then you can check the rear wheel bearings and the 2 no. bearings that are also in the cush drive rear assembly....be sure to photo before and after so that you get the spacers and brackets back in in the right places and order.......
Admin
Site Admin
PostPosted: Mon Jun 11, 2018 9:49 am    Post subject: Reply with quote
Hiya
This is the master cylinder on mine.
http://www.alfa-pages.co.uk/TempPicture/DSC_0831.JPG
Big piccy so just a link.
On the clutch side I have the original master cylinder but I have an adjustable lever fitted (sourced from Wemoto , on the fzr1000 section).
Katy
daward
PostPosted: Mon Jun 11, 2018 8:02 pm    Post subject: Reply with quote
Thanks Katy
PostPosted: Mon Jun 11, 2018 8:21 pm    Post subject: Reply with quote
Thats a brembo black series brake master...used on Ducatis also.....the slightly more modern Gold series is still available new...like these below....although you'd still need to buy the reservoir pot, short run of brake line hose, 2 clips and the alloy perch/support
at least these come complete with the micro switch and cables for the front brake switch
https://www.ebay.co.uk/itm/Brembo-serie-oro-PSC-15-axial-gold-series-brake-master-cylin/142027084225?hash=item21117951c1:g:UD8AAOSwGIRXYnzf
https://www.ebay.co.uk/itm/Brembo-serie-oro-PSC-16-axial-gold-series-brake-master-cylin/142027084381?hash=item211179525d:g:YRIAAOSwvg9XYnzy
OR...you could go bigger diameter piston and Full On Brembo Radial master complete with pot...switchable diameter 18/20...complete with all the bits needed.....can thoroughly recommend...finger type light control and power...
https://www.ebay.co.uk/itm/BREMBO-RCS-FRONT-BRAKE-MASTER-CYLINDER-RCS-19-KIT-OIL-TANK-110A26310-110A26385/272848708537?epid=1083836501&hash=item3f870ce3b9:g:dGUAAOSwmFpZt~-H
Other sellers and masters are available.....wouldn't go chinky Chinese though...like this one at a quarter of the price......
https://www.ebay.co.uk/itm/ANODIZING-Motorcycle-19RCS-Black-Brake-Adelin-Master-Cylinder-Hydraulic/263276776274?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D2%26asc%3D49138%26meid%3Df1e95bdfb8e946abb755cc2857906073%26pid%3D100005%26rk%3D2%26rkt%3D12%26mehot%3Dpp%26sd%3D272848708537%26itm%3D263276776274&_trksid=p2047675.c100005.m1851
PostPosted: Tue Jun 12, 2018 5:56 am    Post subject: Reply with quote
Katy
Katy, i pulled my rear hugger off. Some cracking around the mount and previous repair. Its in a decent shape so I thought about getting it repaired and refinished but after reading about your CF hugger I am interested. Please post a link so that i can take a look. Thank you.
1991 Bimota YB10
2001 Yamaha R6
2007 Aprilia Bol d’Or
Admin
Site Admin
PostPosted: Tue Jun 12, 2018 10:02 am    Post subject: Reply with quote
Hiya
Ordered from here
https://www.motoforzafairings.com/rear-fender-hugger-bimota-yb10-91-93
They do them in grp , carbon fibre or Kevlar. While cf is more expensive than grp the postage makes it less difference than it first appears.
Katy
PostPosted: Wed Jun 13, 2018 5:02 am    Post subject: Reply with quote
Katy, thanks for the link. I'll wait to see how your hugger looks before pulling the trigger. I like Kevlar, pretty unusual color. Wonder how that would look with the Dieci colors...
1991 Bimota YB10
2001 Yamaha R6
Admin
Site Admin
PostPosted: Thu Jun 14, 2018 2:17 pm    Post subject: Reply with quote
Hiya
Hugger arrived just now.
Big piccy so a link:-
http://www.alfa-pages.co.uk/TempPicture/DSC_0842.JPG
Katy
Page 3 of 4
