New member
speed748
PostPosted: Sat Jun 09, 2018 9:11 am    Post subject: New member Reply with quote
Hi all
I have just purchased an SB7 from Switzerland, I'm taking delivery of the bike hopeful Tuesday what should I check on it?
PostPosted: Sat Jun 09, 2018 9:37 am    Post subject: Reply with quote
Check it starts Laughing
Welcome to the forum
PostPosted: Sat Jun 09, 2018 12:17 pm    Post subject: Reply with quote
Check that the fuel injection runs...and same with bike....and depending on mileage....the dreaded front sprocket and clutch slave unit and sprocket cover....welcome to the Forum
PostPosted: Sat Jun 09, 2018 1:07 pm    Post subject: Reply with quote
Personally I change all the fuel hoses, or at least inspect them.
Welcome to the forum.
djk
PostPosted: Sat Jun 09, 2018 9:28 pm    Post subject: Reply with quote
Hoses in the the fuel tank can fall apart over time especially if left sitting in fuel, i suck out most of the fuel after a ride to leave a semi dry tank. The position of the fuel pump as well, if its at the front it will never pick it all up, if its at the back no problems.
If your lucky the fuel injection will be ok, if not below 5-6rpm it will be almost unrideable above that it clears and goes wonderfully. I used a power commander for a 1998 GSXR750 and the dyno technician spliced it in.
Oil filler cap can be fiddly to get too as well so i ground down a hex head to fit, another member suggested to use the breather hose to fill up.
PostPosted: Sat Jun 09, 2018 11:02 pm    Post subject: Reply with quote
Welcome to the forum. Good choice of bike.
