Posted: Wed Mar 28, 2018 6:04 pm Post subject: Clocks Away ! |
so, last night I engaged the SB6R in combat and finally it yielded it's clock set, but not without a struggle............
clock set now despatched to sunny Norfolk to (hopefully) have it's errant speedometer repaired.............
and whilst the hammer and chisel were still warm, I removed the rear seat unit in preparation for a deep cleaning session...........
not that it really needs one  _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Posted: Wed Mar 28, 2018 8:19 pm Post subject: |
You needing a "cleaner" Geekay? I know a good pair of hands for that going spare.....No wonder your clocks are broke...what speed is that needle stuck at??? Were you trying to go back to the future??? |
Posted: Wed Mar 28, 2018 8:29 pm Post subject: SB6R clocks |
Geekay, many have replaced the stepper motors on those clocks, including me, without much in the way of success. They are not a quality item! I replaced mine with a set of Koso, which have served me well, at not a huge cost. _________________ What, Jonny's gone! |
Posted: Thu Mar 29, 2018 7:24 am Post subject: |
2bims wrote: |
just changing into 5th when it stuck.................  _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Posted: Thu Mar 29, 2018 7:27 am Post subject: Re: SB6R clocks |
Jonny B Bad wrote: |
Geekay, many have replaced the stepper motors on those clocks, including me, without much in the way of success. They are not a quality item! I replaced mine with a set of Koso, which have served me well, at not a huge cost. |
I would like to keep the standard clocks if possible. I am not a big fan of Koso clocks. but I do have a spare Tesi 1D digital unit on standby..........  _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Posted: Thu Mar 29, 2018 7:42 am Post subject: Re: SB6R clocks |
GeeKay wrote: |
I would like to keep the standard clocks if possible. I am not a big fan of Koso clocks. but I do have a spare Tesi 1D digital unit on standby..........  |
Nowt wrong with the Koso stuff....albeit a bit low budget....but not really period keeping with the bike.....probably less chance of your Tesi clocks working than the original SB6R ones...teehee |
Posted: Thu Mar 29, 2018 7:45 am Post subject: |
GeeKay wrote: |
2bims wrote: |
just changing into 5th when it stuck.................  |
Ah....so you even ride your own bikes like you rode my Vdue then Eh??/ |
Posted: Thu Mar 29, 2018 8:40 am Post subject: |
Your probably better off junking the insides of the speedo and fitting a new unit behind it, keeping the face and needle. Then calibrate it. _________________ Don't read everything you believe |
Posted: Thu Mar 29, 2018 9:54 am Post subject: |
2bims wrote: |
Yep - we were running late to catch the Chunnel train m'lud.............. _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Posted: Thu Mar 29, 2018 9:55 am Post subject: |
Evilchicken0 wrote: |
Your probably better off junking the insides of the speedo and fitting a new unit behind it, keeping the face and needle. Then calibrate it. |
Think fitting a Koso unit is easier than that option  _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Posted: Thu Mar 29, 2018 1:55 pm Post subject: |
Shrug ... its not you have to calculate the burn, or limit the impurity, control pitch and yaw and then think of a recovery system _________________ Don't read everything you believe |
Posted: Fri Mar 30, 2018 10:16 am Post subject: |
I have managed to graft a Triumph Sprint speedo into a Suzuki Katana instrument pod, but there are sod-all electronics involved in that. _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Spongebob
Posted: Sat Mar 31, 2018 4:37 pm Post subject: |
Do you mind me asking who you sent them to? |
Posted: Sun Apr 01, 2018 9:28 am Post subject: |
http://www.scorpio-electronics.co.uk/ _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Posted: Sun Apr 22, 2018 2:18 pm Post subject: |
clocks ahoy!
stuck at 40 km/h - will have to plug them in and see if they rectify themselves.
signs of forced entry...............
