2Bims Clearout
PostPosted: Mon Jul 30, 2018 9:43 am    Post subject: Reply with quote
who wrote:
https://i.imgur.com/3UtGQ1Wh.jpg
Hi Steve can you shoot me a price one these? Cheers.
Both steering stem caps accounted for now unfortunately.....I know that Rudolf has had them remanufactured....as "one size fits all" on the Bimota range...SB2 thru to SB6/7...DB1-DB4.....KB1-KB3...YB4-YB11.....he's asking 75 euros a pop though
https://www.bimota-parts.de/en/component/virtuemart/db2/lenkkopfrohrmutter-detail.html?Itemid=470
Gammaboy
PostPosted: Mon Jul 30, 2018 11:21 pm    Post subject: Reply with quote
I've got a stem dust cap - comes with a set of SB6 forks/triples though!
PostPosted: Tue Jul 31, 2018 7:33 am    Post subject: Reply with quote
"breaking" them down to parts may be an easier way to sell....big heavy forks are expensive to post though, and that holds some folk back from buying
PostPosted: Wed Aug 01, 2018 9:09 am    Post subject: Clear-out Reply with quote
Hello 2bims
pm sent.
PostPosted: Wed Aug 01, 2018 11:48 am    Post subject: Reply with quote
Right back atchya Johnny
PostPosted: Wed Aug 01, 2018 12:10 pm    Post subject: Reply with quote
Final parts remaining.....3 shipments gone to the USA....2 to UK...and 5 to Australia so far...so we know where the money/interest in Bimotas is eh??
Adjustable "travel size" (150x20x10mm) pair of eccentric adjusters for all Bimotas with eccentrics on the rear wheel....hand made from billet with SS bolts and lugs...one fixed one adjustable (because Bimota fitted different sized eccentric blocks to different bikes...of course)
Ducati 750/900SS rear view mirrors...also fit Bimota YB10 and others (NOS)
Bimota Vdue Oil tank/Petrol tank securing bolt/cap...Bodywork spacer...51mm steering damper fork bracket....alloy footpeg insert sleeves and alloy locking nut (bimotas with rubber inserts on the pegs)..Brake foot lever to brake rod connecter swivel....
Slight mark on face of Vdue oil tank/petrol tank securing bolt/cap
brembo rear caliper for most Bimotas...and hanger plate
foopeg inner alloy sleeves/bearing roller
gear rod end swivel that locks with the gear rod foot lever
Theres a mudguard to lower fork leg fixing clamp here...just one half...49mm dia
Gear shaft splined end connecter to gear rod - Oil crankcase filler cap in Billet alloy - Billet alloy oil thermister temp gauge sender for oil line banjo fitment
Pro Bolt alloy turned and tapered and grooved gear shaft rod 210mm long
Theres also a 290-300 adjustable carbon Bimota gear shaft rod...orignally only fitted to the SantaMonicas...but they also fit the Bimota Vdue which has a LOng throw on the gearchange
For all those that have already bought...thanks very much...and for those that I have exchanged discussions and said will hold parts whilst measurements/checks are made etc...all your parts are seperate from all of these already.....so Bri...Paul....Lammie....Johnny and Geekay etc
After this weekend...they will be posted up on the Bimota Specific Facebook Pages and anything left after that will be ebay...so..last chance on here before the advertising is opened up outside of this Forum
PaulDB2
PostPosted: Wed Aug 01, 2018 12:19 pm    Post subject: Reply with quote
Steve, PM sent.
PostPosted: Wed Aug 01, 2018 12:33 pm    Post subject: Reply with quote
And one sent back to you...and I sent you a text before this message and previous post that should have negated both of our efforts
PostPosted: Wed Aug 01, 2018 1:57 pm    Post subject: Reply with quote
Hi 2bims.
You decided if you going to sell me the DB6 headlight yet and what the price is?
PostPosted: Wed Aug 01, 2018 2:55 pm    Post subject: Reply with quote
Hi 2bims.
Correct
Admin
Site Admin
PostPosted: Fri Aug 03, 2018 3:50 pm    Post subject: Reply with quote
Oh well, never mind. I am just a bit paranoid about that part!
Thank you
Katy
bimota_rider
PostPosted: Fri Aug 03, 2018 4:00 pm    Post subject: Reply with quote
My parts arrived!!!!
I must say: "Well packed, small package and as promised!!!"
Thank You 2Bims!!!
The extra effort and time spent on my project alone is very much appreciated.
(halfway around the world!!!)
Thank you "Good Friend" ....Man, that made me smile!!!
Thank You SOOO Much!!! From Utah, USA
Tom
Very Happy
Built 5/97
2014 Suzuki Hayabusa
2001 BMW R1100S
PostPosted: Fri Aug 03, 2018 4:07 pm    Post subject: Reply with quote
Thank you
Katy
You would have been top of the list....but I've tried to identify who actually "needs" the parts...and yup...need and want have a fine line dividing them for some....and then theres total overlap with others.....Laminator has a "need" as his is cracked....Paul....just shares your paranoia as he had a bike with a cracked one....and 2 others he think may crack....they are still available from Rudolf...so....theres a source IF the untoward should happen...…..
PostPosted: Fri Aug 03, 2018 4:14 pm    Post subject: Reply with quote
Very Happy
Its been said before about me....Glad they got there all in one piece...did "we" manage to avoid the dreaded Tax/Import duties???
bimota_rider
PostPosted: Sat Aug 04, 2018 3:39 pm    Post subject: Reply with quote
Why Yes, we did!!! Very Happy
Don't need no stinkin' Gub-mint..... Twisted Evil Rolling Eyes
Built 5/97
2001 BMW R1100S
Page 4 of 5
