Engine management light
sonny68
PostPosted: Mon Jul 23, 2018 10:48 pm    Post subject: Engine management light Reply with quote
Hi all
I’ve not ridden my Bimota’s in nearly two years. They’ve been in bikecoons with a trickle charger on. Decided it’s time to give them all a run. Got Tesi Anniversary model out and gave it a check over. Put in fresh fuel and started her, she started 2nd attempt. Everything looked and sounded okay except engine management light was flickering. Took her to the local petrol station to fill up, took my time as I wanted the bike to settle. Filled up and went. Engine management light either stays on or flickers at higher revs. Bike has no power 70mph to speed in 5th great if I put her in 6th loose speed will not go over 6000rpm. Engine feels okay but no power, got home tonight and one of the exhaust down pipes was glowing red hot. Bike starts first time every time. Everything works, just engine management light and lack of power. Any ideas?
Thank you in advance.
PostPosted: Mon Jul 23, 2018 11:58 pm    Post subject: Reply with quote
Maybe a faulty sensor has put it into a ‘limp’ mode?
Was it actually hot, or just hot pipes? Maybe running lean for some reason
sonny68
PostPosted: Tue Jul 24, 2018 9:25 am    Post subject: Reply with quote
Could be but I’ve got no idea where to start looking
Temp gauge was on four bars when I pulled into my garage, it smelt hot.
PostPosted: Tue Jul 24, 2018 11:54 am    Post subject: Reply with quote
Guess if one pipe red hot and running rough you have a fuel issue to that pot.
Temp sender on the air cooled twins is not going to be very accurate and is engine block not individual pots.
sonny68
PostPosted: Tue Jul 24, 2018 12:02 pm    Post subject: Reply with quote
It doesn’t sound rough just no power and revs limited occasional pop on deceleration
PostPosted: Tue Jul 24, 2018 1:11 pm    Post subject: Reply with quote
Guess its the usual plug/injector fuel pressure tests to start with.
Glowing header usually running lean.
sonny68
PostPosted: Tue Jul 24, 2018 10:26 pm    Post subject: Reply with quote
Is this something I. An do myself or is it off to the Dealers ?
I do have some knowledge on cars mechanics but never really worked on bikes.
sonny68
PostPosted: Sun Jul 29, 2018 9:51 am    Post subject: Reply with quote
Sorted
Had time this morning to have a good look, I had disconnected the battery in the hope it might be an ecu problem but in the end it was a wire. It looks like a coil pack and there’s one each side either side of the battery. The one behind the horn had the loose connection. Anyway put it back on started great and runs great😀
Thanks for the help.[/img]
PostPosted: Sun Jul 29, 2018 10:18 am    Post subject: Reply with quote
sonny68 wrote:
Sorted
Was it a purple wire?
Shocked
sonny68
PostPosted: Sun Jul 29, 2018 10:35 am    Post subject: Reply with quote
sonny68 wrote:
Sorted
Shocked
Not sure 😁
PostPosted: Mon Jul 30, 2018 11:54 am    Post subject: Reply with quote
Shocked
Nah , that Santa's only Very Happy
PostPosted: Tue Jul 31, 2018 10:50 pm    Post subject: Reply with quote
Shocked
Laughing Laughing Laughing yep
