Bimota SB8RS radiators - Help needed
jgsaramago
PostPosted: Thu Aug 30, 2018 11:55 am    Post subject: Bimota SB8RS radiators - Help needed Reply with quote
Greating to all,
I´ve recently bought a SB6 and SB8RS that I´m now bringing back to full original spec. While testing the SB8RS cooling system I´ve found that both the radiators are leaking due to the lack of use (the bike has less than 3000kms) and I would need to replace both (the v shaped one is OK).
I´ve been reading about and apparently they are made by KTM. Do you know what is the part number or to which model it belongs? If not would you know who can produce the two radiators?
Thanks a lot for your help
Regards
JS
PostPosted: Thu Aug 30, 2018 1:12 pm    Post subject: Reply with quote
Try West Mercia Radiators http://www.westmerciaradiators.co.uk/
jgsaramago
PostPosted: Thu Aug 30, 2018 7:35 pm    Post subject: Reply with quote
Thanks! Just gave them a ring Wink
PostPosted: Thu Aug 30, 2018 9:08 pm    Post subject: Reply with quote
Full set of SB8R radiators for sale here
https://www.bimota-parts.de/en/teileshop.html
