Horseheed
Posted: Sat Sep 01, 2018 5:08 am Post subject: SB6r fuel pipes ? |
Hi, regarding my SB6r running trouble, could it be my fuel pipes? I've got mine running horizontal from air box to fuel rail on the carbs but am I right in thinking the pipes come out of the air box go down and then back up vertically into the carbs Cheers _________________ Horseheed |
Posted: Sat Sep 01, 2018 8:52 am Post subject: SB6R |
Through the airbox and straight onto the connections into the carbs. Look for kinks in the pipes in the airbox. Have you still got the fuel pump in the airbox? If so, ditch it and replace with a pingel 1 in, 2 out fuel filter and run off gravity, which is fine, unless you spend most of the time flat-out on the back wheel, in which case you might suffer some starvation, but only briefly until your collar's felt or some other mishap ![Laughing](images/smiles/icon_lol.gif) _________________ What, Jonny's gone! |
jerry
Posted: Sun Sep 02, 2018 2:39 pm Post subject: |
Hi whats the problem with the fuel pump,why ditch it ( new owner needing info) _________________ jerry SB6R |
Horseheed
Posted: Mon Sep 03, 2018 9:16 pm Post subject: |
jerry wrote: |
Hi whats the problem with the fuel pump,why ditch it ( new owner needing info) |
Hi Jerry, I've read quiet a few posts saying they
cause a lot of trouble under normal running so I decided to remove mine and just run it gravity feed But as mine is not running properly anyway it was just another thing to try Cheers Nigel _________________ Horseheed |
