DB1 restoration
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Rocketron
PostPosted: Sun Oct 21, 2018 5:40 am    Post subject: Reply with quote
Moving to the rear of the bike.
These are the original tires. I've never had the axle out on the rear wheel. It's not obvious how it's removed either. Anybody have some advice how to do this??
Spoke with the parts person at the local Ducati dealer. Apparently Ducati doesn't support well the older motors. Their parts software doesn't go back far enough to give information about cam belts. They have a part number but aren't confident about it. I'll have to do some research and remove the belts so they can compare. Any advice with this would be appreciated.
Learned today I will have to install the clutch master cylinder to allow removal of the clutch slave cylinder. Apparently you use hydraulic pressure to pop the slave piston out. Again, the dealer has no part number for the O-ring inside. I'll have to bring it along to show the size so they may order it. What I've seen there were several iterations of this slave cylinder internals.
Given the mistake with the brake hoses and this discovery, I'll be up to my ankles in DOT 4 brake fluid soon.
One total success for today!!
rpo83
PostPosted: Sun Oct 21, 2018 5:57 am    Post subject: Reply with quote
Loving seeing the DB1 undressed... She is in stunning condition
As Gerald said "both holes are M10x1.0 with a bevelled seat to take the bleed nipple" check the seats of both holes, if they are bevelled you can leave the setup as it is, having the bleeders outboard would make bleeding easier...
Keep up the good work..
Steve
1988 YB5
1995 SB6
Rocketron
PostPosted: Sun Oct 21, 2018 8:44 pm    Post subject: Reply with quote
Of course!
Use the owners manual.
Highly detailed Bimota owners manual instructions for front suspension.
DB1 860
PostPosted: Sun Oct 21, 2018 8:57 pm    Post subject: Reply with quote
I've used compressed air to get the slave cylinder out.
PostPosted: Sun Oct 21, 2018 10:01 pm    Post subject: Reply with quote
Classic mistake in rear wheel spindle removal made by most with DB1/DB2.....as removing the half moon eccentric caps from the back merely removals the whole unit.....you'll be putting it back in and nipping them up to remove the outer cap from the inner of the concentric....Look at Tav 21 in the spare parts booklet here....the allen key bolts offset on either side of the eccentric alloy blocks Left and right are screwed into the rear wheel spindle.....so put back wheel back in swingarm and nip up the half moon collets and loosen allen bolts both sides....axle spindle is also held in the eccentrics by one number mini dowel/pin on either side......so once the allen bolts are out....loosen one side of half moon collets and try to turn the eccentric to loosed one side of the spindle from the pin/dowel that holds it tight (as it is pushed into place well and solid by the allen bolt.....the other side you can leave in place as only one side needs to be removed to extract spindle....the rear brake caliper hanging plate and two cover plates are threaded onto each other to achieve wheel centering...so check and measure if you are going to pull apart so you ca put back the same.
Yup...Ducati main dealers were forced to do away with the microfiche system for new updated computer systems....which only cover 2000 year onwards bikes....yet they still have parts and can check part numbers....but cant ascertain the parts numbers as they dont have the microfiches anymore with exploded diagrams....use the spare parts manual for this as Bimota didn't re-right the rule book....for engine parts, seals , cambelts....Bimota used the Ducati numbering parts system....Belts easy enough to get over here....and should be a code written on them if its not worn away
(Edited - Stoopid me put a link in to a computer file and NOT an interwebby link thingie as it should have been....)
Check Tav 22 also for the complicated rear wheel alignment set up...theres many bushes and bearings in there....all threaded together to move back wheel to the left or right to align wheels F&R....
Quadrasuarass
PostPosted: Mon Oct 22, 2018 12:21 am    Post subject: Reply with quote
I suggest you get a set of Ducati F1 manuals from Gowanlochs or similar. These have all the original parts numbers for the engine and other bits that are common with the F1
https://ducati-gowanloch.com/shop/ducati-manuals/ducati-750-monjuich-750-f1-workshop-manual/
Also Maxton in the UK are able to do a set of cartridges for the front forks that have full adjustability while retaining the fork caps reservoirs. They can do a rear shock as well.
Rocketron
PostPosted: Mon Oct 22, 2018 1:56 am    Post subject: Reply with quote
Both holes are beveled at the bottom. So that is why the bleed screws were working in the outer holes.
Bleeding isn't much more difficult with the bleed screw in the inner hole. Hate to try it with the fender on...
Rocketron
PostPosted: Mon Oct 22, 2018 3:42 am    Post subject: Reply with quote
Thanks to 2bims explanation and some very careful force. I got the axle out of the rear wheel.
Once you see how it's assembled, it makes sense. But up until that point, you're kind of scratching your head. It's not obvious that's for sure.
Using a little force to get one end off without knowing if you're going down the rabbit hole is a little un-nerving too.
PostPosted: Mon Oct 22, 2018 10:38 am    Post subject: Reply with quote
So....the Suzuki Swtichgear button fits OK....good to see....as it was a bit of a "punt" on my side....ahem....and rear wheel out....I've now emailed you the full Exploded Parts Diagram manual also....as apparently when read from Canada and often from down under it wont open??..Is this just Canada, Oz and NZ? can other people open these links successfully???
Number 1 - From BCP website
https://www.sfogliami.it/flip.asp?sc=5hbl9ofivqjerrijhgdjtmk1jc5kcse5&ID=117560
Number 2 - From Bimota-parts.de
https://www.bimota-parts.de/images/PDF/Catalogo_Ricambi_DB2.pdf
Quadrasuarass
PostPosted: Tue Oct 23, 2018 4:56 am    Post subject: Reply with quote
Both of those open fine in NZ when I'm at home. I've had issues when trying to open items like this at work as the firewalls there are quite restrictive.
PostPosted: Tue Oct 23, 2018 9:19 am    Post subject: Reply with quote
Cheers Quad for Confirmation....just dont want to be wasting my time posting links for folk if they dont work ..although my initial posted link was a senior moment of posting a link to a file on my hard drive...that simply was never going to work...
Would be nice if we could have a "cloud" link somewhere on the Forum...and I'd download all my pdf workshop manuals, owners handbooks, Exploded parts manuals etc....
Rocketron
PostPosted: Wed Oct 24, 2018 12:35 am    Post subject: Reply with quote
These links working for me. The exploded drawings for the DB1 you sent via e-mail are quite useful. I've been able to confirm the timing belt part number given to me by the dealer.
Yes, useful but doesn't compare to a recent Yamaha shop manual.
Took a little different route with the clutch slave cylinder. Air wasn't doing it and I'm fed-up cleaning brake fluid up.
A little rougher than I expected at the base of the cylinder. I'll leave it to soak with cleaner before using any abrasives. Base of the piston looks pretty good, happy with that.
Rocketron
PostPosted: Thu Oct 25, 2018 3:45 am    Post subject: Reply with quote
The power of DOT4 brake fluid to remove paint is amazing. I wonder if paint stripper uses it? I rubbed the crystallized fluid off the lower portion of the left bar switches and this happened.
One of the upsides to the bike being so old is the switch housing is aluminium. This does allow some restorative work to be done
A little sand paper then go buy a rattle can of flat black. We'll see if I can make it look good as new.
Rocketron
PostPosted: Thu Oct 25, 2018 3:57 am    Post subject: Reply with quote
As I was planning the next steps it occurred to me that I might be overlooking somethings I should be replacing or checking.
It seemed to me that someone else may have already figured out what needs to be checked out.
I've pretty well covered the:
Brake rebuild
Suspension over-haul
The future for me is to:
Replace the timing belts
Replace the clutch slave O-ring
New spark plugs
New fuel hoses and vacuum hoses
New tires and valve stems
Change the oil and filter
Anything else come to mind?
Quadrasuarass
PostPosted: Thu Oct 25, 2018 4:28 am    Post subject: Reply with quote
While the heads are off it's an easy job to do the valve shims. You may want to consider dialing in the cams.
Check wheel bearings
Check play in swing arm bushes
Page 5 of 10
