SB6R
PostPosted: Sun Oct 14, 2018 6:39 pm    Post subject: SB6R Reply with quote
First registered 1996. 24000kms from new. I am the 3rd owner.
Just had new chain & sprockets (yes - both!) fitted, clutch fluid replaced and new swing arm bearings.
In 2017 it had all new wheel bearings fitted, all fluids (except clutch) replaced and the engine serviced and was set up on John Warrington's Dynostar dyno to cure it's chronic over-fuelling. Now runs spot-on.
A new speedometer stepper-motor has been fitted and calibrated after the original packed in last year.
The top fairing is cracked under the r/h mirror and the r/h fairing panel has cracked where the previous owner over-tightened it.
New Pirelli Diablo Corsa 3's fitted last year - probably covered around 1000 miles since fitment.
6000 ovno.
