Moreno
Posted: Sat Dec 08, 2018 8:50 pm Post subject: Littel problem clutch |
I have problems with the clutch because I realized that it slips when the bike reaches full power ..... Then today I removed the clutch and I found the hot discs turned blue. my curiosity is that I also found a little 'oil in the clutch crankcase !! can it be for what the fraction slips? Is it normal to find some oil in the clutch crankcase? .... it's not so much oil it's just a little more than a small spoon |
Weed
Posted: Sun Dec 09, 2018 9:43 am Post subject: |
You should have no oil there. It is a dry clutch. Replace the seal etc |
Moreno
Posted: Sun Dec 09, 2018 11:14 am Post subject: |
are a few drops of oil .... but I think they create problems, I have to take some new seals and the new clutch plates ...... the ducati disks are good both those with coating as I have already said, but are good even those in the middle in metal only? |
2takt junky
Posted: Sun Dec 09, 2018 12:50 pm Post subject: |
I'm afraid it's nothing new.
Replace the shaft sealing ring and clean the steel and the clean letters and that's it. |
