Alan simons
Posted: Sun Jan 27, 2019 7:11 pm Post subject: Sb6 seat ,tank unit removal |
Seat tank unit Sb6 tried to remove when lifting back over seams to still fixed to pipes , have removed all fixing visible is there any under seat thanks _________________ Yb9 , db4 , SB6 , SB6r , BMWrt 1200 |
Posted: Sun Jan 27, 2019 10:34 pm Post subject: |
4 securing bolts under the "bum stop" that attach the exhaust sub frame to the seat unit. _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Posted: Sun Jan 27, 2019 11:00 pm Post subject: |
It's tricky the first few times. Once all of the bolts are out, lift the front, wiggle and pull it back a little. Then you have to tilt it to one side and lift over the pipes. I find putting one hand either side and prizing the sides open a little down near where the 4 countersunk fixing screws are also helps _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Sun Jan 27, 2019 11:02 pm Post subject: |
| brian wrote: |
| It's tricky the first few times. Once all of the bolts are out, lift the front, wiggle and pull it back a little. Then you have to tilt it to one side and lift over the pipes. I find putting one hand either side and prizing the sides open a little down near where the 4 countersunk fixing screws are also helps |
Also need to disconnect the wiring plug for the rear lights. L/H side inside the side of the seat unit _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Sun Jan 27, 2019 11:04 pm Post subject: |
It's also possible to leave the mufflers bolted to the seat unit.... but it's a pain to get to the retaining springs on the pipes. It's also a pain to put back together this way. I prefer to unbolt the muffler support bracket from the seat unit and leave the mufflers on _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Mon Jan 28, 2019 10:21 am Post subject: |
I go underneath the seat unit and remove the 2 bolts between the mufflers. the subframe stays attached to the seat unit. _________________ Don't read everything you believe |
