Gammaboy
Posted: Thu May 09, 2019 3:36 am Post subject: |
pkay wrote: |
There's a pic of the new SB6 in wrapping on Facebook. Is he selling the SB7's, haven't seen them advertised anywhere. |
It's in the next container i believe |
djk
Posted: Thu May 09, 2019 3:48 am Post subject: |
The first time i pulled my SB7 apart i found the ECU wasn't in the best of locations, it's sort of wedged between the motor and radiator on the right side of the bike. It is in a plastic housing and when i opened that up water was at the bottom of it. I have never ridden the bike in the rain and by the looks of it i don't think it has ever seen rain so i'm guessing the water could be condensation, not too good for it i would imagine. |
Gammaboy
Posted: Thu May 09, 2019 5:18 am Post subject: |
djk wrote: |
There's not really a lot of spare real estate on the SB6, so I can imagine the location of the ECu was a bit "wherever the fuck it fits"... something modern like a Microsquirt (the small footprint Megasquirt) *should* be able to be fitted on the side of the battery box as per the SB6 ignition box... should be a bit more waterproof too! |
djk
Posted: Thu May 09, 2019 7:52 am Post subject: |
I am using a lithium battery at the moment so have a spare battery box and looked at trying to put the ecu in there but it was just a little too big to fit comfortably, i am sure it would with some persuasion but that is in the to do list. |
Gammaboy
Posted: Thu May 09, 2019 11:16 pm Post subject: |
djk wrote: |
I'm using a pair of 4 cell lithiums - almost the same weight as a single 8 cell, but having the battery hanging to one side would do my OCD in. |
Gammaboy
Posted: Fri May 10, 2019 12:07 am Post subject: |
Question related to SB7s - what is the deal with this carbon airbox intake cover? Digging around the internets, it appears on most of the SB7s that I can find photos of, and looking in the parts book, it appears to take 2 cold air feed pipes (not able to be fitted to the SB6 due to the hydraulic clutch slave maybe?)
djk
Posted: Fri May 10, 2019 7:41 am Post subject: |
Not home at the moment but my bike definitely doesn't have that fitted, will have a look when i get home and see what it does have, from memory i think it is just a triangle cut out on the left hand side.
Yup it is just a sort of triangle cut out at the bottom of the airbox. |
