Hursty
Posted: Wed Mar 13, 2013 10:34 pm Post subject: SB 6 Radiator cap |
I am starting to suspect I may be in need of a new Radiator cap as I am still loosing a little fluid
It was fine being overheated on the dyno and at the track day but getting stuck in traffic in 27 c seems to be a problem
I recall reading in one of the threads that its not going to be easy to get a new replacement cap and I might have to get the neck of the radiator modified for a different one
Please clarify this for me so I can sort it out with minimum time off the road.
Cheers  _________________ Hursty from kiwi land  |
Posted: Wed Mar 13, 2013 11:51 pm Post subject: SB6 Rad Cap |
Hursty, I guess the 6 cap is the same as the 6r. Perhaps Oily could confirm, as owner of both? If so I can confirm that a comprehensive search could not turn one up. So I got a new neck with an outlet for the reservoir added on. A fabricator for the Motorsport industry should be able to sort you out. _________________ What, Jonny's gone! |
Posted: Thu Mar 14, 2013 11:14 am Post subject: |
Hursty,
Are you sure it’s the radiator cap? (I do not mean this as a criticism, just want to help)
I ask you this question because if it is difficult to get a radiator cap it would be probably expensive to get one and it could be a waste of all the effort to get one if it’s not causing the problem.
Try to look more critically at the problem.
Are you 100% sure that the leaking starts at the radiator cap?
If yes, check/inspect the seals of the cap.
Check the neck for cracks or irregularities where the seals touch/sealing the neck.
Maybe you can fix the problem or temporary fix it and look for new parts.
If you not 100% sure remove the connector of the (fan) thermostatic switch.
Start the engine and heat it up (use common sense you don’t want to make a giant cigarette lighter)
Use a torch/flashlight (how you call it) and a small mirror and inspect the cooling hoses.
At the same time monitor the cooling reservoir, the level should raise if not check for an obstruction in the hose to the reservoir.
I hope this way you find the leak so that you can fix the problem. _________________ vince
Posted: Thu Mar 14, 2013 11:46 am Post subject: |
Jonny B Bad wrote: |
Hursty, I guess the 6 cap is the same as the 6r. Perhaps Oily could confirm, as owner of both? If so I can confirm that a comprehensive search could not turn one up. So I got a new neck with an outlet for the reservoir added on. A fabricator for the Motorsport industry should be able to sort you out. |
Yep, I can confirm.....
They are both the same unobtainium
...It'll be the first time I, personally will have heard of a cap failing.
Only thing that can go wrong is the seal perishing.....  _________________ SB6 mk1 (project mega light, big bore)
Hursty
Posted: Thu Mar 14, 2013 9:52 pm Post subject: |
Thanks Guy's
I hope its something simple (just like me) but after the last leak my mechanic checked ever thing over gave all the clips another tweak and then disconnected the thermostat and ran the motor up hot so that it was pumping coolant into the catch tank, and nothing the coolant was up in the steering head cavity from the first leak so we know its coming from that general region.
The joy's of Bimota ownership never seem to end  _________________ Hursty from kiwi land  |
Posted: Thu Mar 14, 2013 10:03 pm Post subject: |
Hursty wrote: |
There are a couple of places the leak could be coming from in that area.
As Vince has said, run it up to temp and keep searching until you find the leak  _________________ SB6 mk1 (project mega light, big bore)
Posted: Thu Mar 14, 2013 11:37 pm Post subject: SB6 Rad cap |
Shame on you Oily - you of all people should know that what can be relied upon never to occur on any other bike will undoubtedly happen on a Bimota. I had a catastrophic failure on mine - i.e. a crotch full of hot coolant. I knocked up a new seal and the thing still leaked. So I junked the neck and had a new one made up for which caps are freely available. I'm steadily working towards having so little of the original bike left that there's nothing left to drop to pieces  _________________ What, Jonny's gone! |
Posted: Thu Mar 14, 2013 11:41 pm Post subject: SB6 Rad cap |
I've also had various hose connections leak. Whereas a CBR 600 which has been twice round the universe over the last 23 years has never lost a drop - and if that doesn't put the curse on tomorrow's commute  _________________ What, Jonny's gone! |
Posted: Thu Mar 14, 2013 11:42 pm Post subject: Re: SB6 Rad cap |
I'm steadily working towards having so little of the original bike left that there's nothing left to drop to pieces  |
As should ALL sensible Bimota owners be doing
How/what exactly did yours fail? _________________ SB6 mk1 (project mega light, big bore)
Posted: Sat Mar 16, 2013 12:45 pm Post subject: SB6 rad cap |
1) rad cap
2) clocks
3) wheels and exhaust raised on the doughnut diet
4) alternator coupler
5) cracked fairings at mounting points
6) gear change pivot ally grinding on ally
7) fuelling to cock
fuel warning light sensor
9) dissolving fuel tank
10) side stand
I'm going to stop now 'cause my head's starting to hurt! _________________ What, Jonny's gone! |
Posted: Sat Mar 16, 2013 7:57 pm Post subject: Re: SB6 rad cap |
1) rad cap
2) clocks
7) fuelling to cock
10) side stand
I'm going to stop now 'cause my head's starting to hurt! |
That's just fettling. _________________ Don't read everything you believe |
Posted: Sun Mar 17, 2013 9:53 am Post subject: Re: SB6 rad cap |
1) rad cap
2) clocks
7) fuelling to cock
10) side stand
Looks like you managed to get hold of one of the better examples there JBB
And to be fair, the alternator coupler isn't Bimota so that makes it a really good example  _________________ SB6 mk1 (project mega light, big bore)
Posted: Mon Mar 25, 2013 8:38 am Post subject: |
Hursty,
Update please
Have you find the problem yet  _________________ vince
Hursty
Posted: Mon Mar 25, 2013 8:55 am Post subject: |
No progress yet the hot weather here has peaked and its back to the low 20s so its not leaking at the moment and my mechanic has been busy with race bikes but thats over now and i also want a little more dyno time to fine tune the low rpm its still a little off in the 3-4000 rpm range so will strip it down again in the next few weeks.
Will update when sorted  _________________ Hursty from kiwi land  |
Gammaboy
Posted: Fri May 03, 2019 6:57 am Post subject: |
May have stumbled onto a rad cap that fits that's not the 1.8bar KTM unit... The rad cap on mine was one of the pieces robbed when it was being canabalised for spares - but i had a few different caps floating around the workshop, a couple of suzuki ones, an aftermarket one that came with a weld on radiator neck for another project... and one that came on an Aprilia RSV4 radiator I was looking at using on said other project... anyway, the RSV4 cap is spot on - the RSV4 neck is the same dimension as SB6.
Downside/upside (depending how you look at it), it's a 1.4 Bar rating (is stock 1.1 or 0.9?) - which in theory raises the boiling point of the coolant a bit, but does result in the cooling system running at higher pressure... however as far as I can see, hose and connection construction hasn't changed, gaskets are much the same, radiator wall thicknesses don't appear to have increased, so the cooling system should be able to cope.
Curiously, the RSV4 guys are putting the KTM 1.8 bar cap on their trackbikes to give them some more cooling capacity (cooling capacity is related to the temperature delta between the coolant and the ambient air - so the higher a coolant temp you can run, the more energy you can dump through a given size radiator) without having to go to the (even bigger) big racekit rads...
I have a suspicion that the Ducati ST3/ST4 cap might do the job to, and it's a 1.1bar |
