BimotaBoy
Posted: Tue May 07, 2019 7:38 am Post subject: oil change |
| just done an oil and filter change on the YB10. Who ever did it before put the outer cover on upside down and left the washer out. What's with the spring and plug thing in where the drain plug goes, never seen that before Any one got any ideas? What happens if I just put the drain plug in and not all the spring gubbins ? |
Posted: Tue May 07, 2019 9:15 am Post subject: YB10 oil change |
I suspect you have removed the bypass valve, rather than the sump plug - all of that gubbins needs to go back in again and the sump plug, which is on the left-hand side of the sump and may have a cross head screw in its head, should be used for draining the oil. _________________ What, Jonny's gone! |
BimotaBoy
Posted: Sat May 11, 2019 9:59 am Post subject: opps |
| Thanks for that, I did put it back in as I'm off on a road trip tomorrow to the Italian border I'll leave it be till the next oil change. Did get a load of oil out so not all is lost |
