Tail vents
PostPosted: Thu Jul 04, 2019 9:35 am    Post subject: Tail vents Reply with quote
To assist Brian satisfy his curiosity about SB6 tail pieces, I measured the tail piece vents on my Mk1 SB6 - the visible mesh area - and they came in at 325mm long and 45mm at the highest point.
Brian has measured his Mk2 vents and they are 345mm and 58mm respectively indicating that (possibly) a new mould was made for the Mk2 ?
Boris - can you assist Brian by measuring the vents on your SB7 tail piece please ?
And maybe a picture or 2 of the mysterious "tabs" you told me about?
Thanks.
PostPosted: Thu Jul 04, 2019 6:18 pm    Post subject: Reply with quote
OK - I'm away this weekend.
The tabs are the SB6 Mk2 tail
Gammaboy
PostPosted: Fri Jul 05, 2019 12:04 am    Post subject: Reply with quote
Well... this gets weird. My Tail vents (well, the left hand one, haven't measured the right hand one, will do that tonight - I bet they're assymetric) are 345x45. Has the "tabs" for the plate mount too.
Boris sent me this pic a while ago - I've circled the "tabs" in yellow, and the "M" paint pen marking that is common with mine in green.
PostPosted: Fri Jul 05, 2019 3:38 pm    Post subject: Reply with quote
weird indeed - lets see what Boris measures his (SB7 tailpiece) vents at.
Gammaboy
PostPosted: Sat Jul 06, 2019 7:26 am    Post subject: Reply with quote
Measured close enough to 345x45 on the other side.
djk
PostPosted: Sat Jul 06, 2019 9:57 am    Post subject: Reply with quote
I'm measuring 320x45 on the left side and 325x45 on the right side on my SB7.
PostPosted: Sun Jul 07, 2019 10:43 pm    Post subject: Reply with quote
Thank God someone has the same measurements as me !!!!!! Very Happy Very Happy
