DB1 Oil pressure switch
ANTDB1
PostPosted: Sun Jul 21, 2019 1:25 pm    Post subject: DB1 Oil pressure switch Reply with quote
Hi Guys
So close to getting my DB1 finished after a 12 month freshen up but once it came to life, the oil pressure switch is literally spraying oil up the middle and needs to be replaced. Any ideas on where to get one? I want to try keep it the same single blade type fitting but can't find one anywhere on line that looks the same.
Thanks in advance!
Weed
PostPosted: Sun Jul 21, 2019 1:58 pm    Post subject: Reply with quote
Early 916 ones fit Ant?
ANTDB1
PostPosted: Sun Jul 21, 2019 2:25 pm    Post subject: Reply with quote
I was thinking that mate. They look a little different, I think the terminal is offset but it is a single spade type. I'll have a look round back and shop and see if I have one kicking about to try.
