DB6R Delirio circumference setting
jirka-st2
PostPosted: Sun Aug 15, 2010 4:24 pm    Post subject: DB6R Delirio circumference setting Reply with quote
Hello everybody,
I am new owner od DB6R Delirio and only one problem I see. The speedometer shows speed, which is in km/h higher aprox. for 20%. Is it possible to adjust somehow the speedometer - egg. circumference setting? I´ve looked at Koso rx2 manual, which is the same type of speedometer, but these functions, how to open service screen are inactive. Thank you in advance for help.
Jiri
PostPosted: Sun Aug 15, 2010 9:48 pm    Post subject: Reply with quote
I'd replace the clock with a Koso aftermarket unit until Bimota sort them out it should be a striaht for plug in
waldorf
PostPosted: Fri Oct 01, 2010 1:38 pm    Post subject: Reply with quote
The Marelli ECU should have a 10% offset in the peed reading when stock.
That setting can be changed with the Tuneboy software but I highly recommend changing the ECU to a Microtec or Nemesis
Olivier
