Db4 Front Sprockets
PostPosted: Sat May 24, 2014 1:02 pm    Post subject: Db4 Front Sprockets Reply with quote
Firt time I've seen these advertised as being available from a UK supplier...dimensions on there match exactly the one I replaced on my DB4........
http://www.ebay.co.uk/itm/330987364530?_trksid=p2055120.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Corona
PostPosted: Sat May 24, 2014 11:56 pm    Post subject: Reply with quote
They won't fit the fuel injected model as the outside is recessed for the retainer to fit, this also affects the sprocket alignment. 750 Paso ones fit the ie models which is a bit of a headache, wemoto can get JTL sprockets in alloy or steel for the rear.
PostPosted: Sun May 25, 2014 9:35 pm    Post subject: Reply with quote
So 750 Paso front sprockets have the 3mm recess in them ?
The db4 and the db2 have the same recess as the db4ie.
elmisti
PostPosted: Fri Dec 20, 2019 6:39 pm    Post subject: Reply with quote
you find sprockets in germany at
https://www.wieres.com/Shop/1226-15
i bought this for my db 4 i.e. just a week ago and used another one before
db4i.e. Le Mans III Elefant i.e. Gran Canyon Sportster
