SB6 Shennanigans
pkay
PostPosted: Mon Dec 02, 2019 4:40 am    Post subject: SB6 Shennanigans Reply with quote
Never being one to leave well enough alone I want to ditch the pod air filters and return my SB6 back to a standard airbox set up.
But, someone has moved the battery to the airbox position and there is only one instead of the standard 2. I fear what someone has done to the wiring to get to this position. Here we go again.......
Easy question to start, what is the spec of the OEM batteries for the SB6? Brand and type would be great.
Ta
pkay
PostPosted: Mon Dec 02, 2019 2:18 pm    Post subject: Reply with quote
Depends on the SB6.
The early ones had 2 x 6v batteries in series , the later ones had 2 x 12v in parallel. Only real difference was the the link wires between the batteries , and as you don't have them I guess you can go with either set up.
So whats the SB6 ? MK1 or 2 ?
pkay
PostPosted: Tue Dec 03, 2019 2:03 am    Post subject: Reply with quote
Depends on the SB6.
What's the difference between a Mk1 or Mk2?
pkay
PostPosted: Tue Dec 03, 2019 5:49 pm    Post subject: Reply with quote
What wheels has it got?...3 spoke Oscom BImota branded with flat ribs.....or 3 spoke Marchenesi wheels or Antera swirly 3 spokes?
PostPosted: Tue Dec 03, 2019 7:44 pm    Post subject: Reply with quote
Easier ... do the brake and clutch have separate fluid reservoirs or are they the black all in one with the master cylinders
pkay
PostPosted: Thu Dec 05, 2019 12:08 am    Post subject: Reply with quote
Separate, all in one that sounds like solving a problem that didn't exist.... Shocked
pkay
PostPosted: Thu Dec 05, 2019 11:16 am    Post subject: Reply with quote
They changed from Suzuki parts to Brembo Goldline
pkay
PostPosted: Fri Dec 06, 2019 12:26 am    Post subject: Reply with quote
No I've got the good old Suzuki ones.
pkay
PostPosted: Fri Dec 06, 2019 2:55 am    Post subject: Reply with quote
pkay wrote:
Depends on the SB6.
2nd engine mount hole in main frame spars, clocks, master cylinders, headlights, very slight differences in bodywork, wheels, brake rotors, switchgear, batteries
PostPosted: Fri Dec 06, 2019 10:12 pm    Post subject: Reply with quote
That's a Mk 1 then.
Gammaboy
PostPosted: Sat Dec 07, 2019 3:19 am    Post subject: Reply with quote
You'd have to be thick to put the hard to find 6Vs in it.
Pretty sure Centrepoint have an airbox on the parts SB6 they have.
At a guess, they'd have extended the earth cables, moved the starter relay from behind the headlight to the side of the battery box and extended the power feed from behind the original state relay position.
Gammaboy
PostPosted: Sat Dec 07, 2019 3:24 am    Post subject: Reply with quote
Also, last time I looked at the parts bike it was complete enough for you to be able to look at the wiring as it originally was. They may have pulled it apart since though.
And why is this in the bikes for sale forum?
