db 4 i.e. wiring, m-unit basic, marchesini ktm wheels
elmisti
PostPosted: Fri Dec 20, 2019 6:15 pm    Post subject: db 4 i.e. wiring, m-unit basic, marchesini ktm wheels Reply with quote
hi there,
my name is ludwig from germany. i bought my db back in 2000 new. i changed it to an underseat exhaust and a ducati half fairing.
i cant post images, because i dont have a webpage. i could send an email to someone, who can post the photo for me on a webpage.
at the moment i adapt marchesini ktm SMT R wheels.
it will get a lithium ionen CS battery
https://cs-batteries.de/Lithium-LiFePO4-Motorrad-Starter-Batterie-PRO-V2-mit-BMS-inside-12V-75Ah-450A-106-x-76-x-82mm-1160g
and a mosfet regulator
https://cs-batteries.de/Elektronischer-Mosfet-Spannungsregler-Gleichrichter-fuer-Drehstrom-Lichtmaschinen-und-LiFePo4-Batterien
finally i want to install a motogadget m-unit basic. i need a wiring diagramm for the db 4 i.e. the db 4 wiring icould find has no fuel injection, so it doesnt help.
anyone around, who has an idea. is it possible with the magneti marelli ecu?
merry christmas and a happy new year,
ludwig
p.s.: hello riny, you helped me out before and i did send you the chain adapter for your swingarm. hope you can fix your bike.
PostPosted: Fri Dec 27, 2019 12:49 am    Post subject: Reply with quote
Hi Ludwig, I’m interested to see the pics of your DB4ie with the under seat exhaust. What system did you use and was it much trouble to fit? Email me your photos to brianmeechan6@bigpond.com and I’ll post them in this thread
polyesterpig
PostPosted: Tue Dec 31, 2019 5:14 am    Post subject: Reply with quote
The bimota DB4ie used the 2001 Ducati Monster m900ie engine. Find the wiring diagram for the Ducati Monster. It is the same wiring diagram.
2002 Cannondale E440
(3) 2003 Cannondale E440R
2000 Bimota DB4ie BiPosto
elmisti
PostPosted: Fri Jan 03, 2020 7:31 pm    Post subject: Reply with quote
hey brian and polysterpig,
thank you for the informations, that helps.
@ brian: i will send you some photos.
I used a BOS Silencer for a Yamaha 1000 and the tubes are made by http://www.schaefer-rennauspuffanlagen.de/Home
he made the 44mm tubes and the 2-1 piece, the adjusting pieces to the silencers is my work.
Further i tuned the engine a little bit with 944 cc, dual ingnition, the cylinder head and the ecu were optimized. in the end it is good for 88 PS at 7800 1/min and 86Nm at 6000 1/min.
The underseat silencer looks nice in my point of view, but it is also a disadvantage, when it comes to power and torque. The ducati engines harmonizes better with a 2-2 exhaust.
so maybe i will change it again or look for a 1100 ds engine Wink
PostPosted: Thu Jan 09, 2020 5:54 am    Post subject: Reply with quote
Photo’s of Ludwig’s DB4ie
DB1 860
PostPosted: Fri Jan 10, 2020 10:24 pm    Post subject: Reply with quote
Being a Db4 owner as well I was interested in what the exhaust looked like from the back... Its a shame that Ludwig didn't send us that photo.
On a different note Id love to know the name of the red colour that Bimota used on the Db4ie? maybe its the same as the YB11.
PostPosted: Sat Jan 11, 2020 12:29 am    Post subject: Reply with quote
If I was to be critical, and this is only my personal opinion.... the can is a fraction too long, or maybe the mid pipe. Although a shorter mid pipe would put the can under the riders arse. I do like it though, tidied up the bike nicely.
PostPosted: Sat Jan 11, 2020 12:30 am    Post subject: Reply with quote
If Ludwig would like to email me a couple photos from the rear of the bike, I’ll gladly post them up
elmisti
PostPosted: Mon Jan 13, 2020 8:09 pm    Post subject: Reply with quote
Hey brian, you are right. The can was to Long and it is still to thick. I shortened it, but the Pics are old. Now the can ends at the rear end of the seat.
I could fit a smaller can, but than volume is missing. Looks Good, but takes Performance. To bring the pipe higher would make a better look, but there is Not enough room for the electronics.
I will send Pics, when the bike is ready with new wheels.
db4i.e. - Le Mans III - Gran Canyon - Desert X -Sportster
PostPosted: Tue Jan 14, 2020 3:45 am    Post subject: Reply with quote
Cool, I look forward to the pics!
I was worried about mentioning that I thought the can looks too long as sometimes people take offence to remarks about their pride and joy (me included!).
PostPosted: Tue Jan 14, 2020 1:37 pm    Post subject: Reply with quote
Well the db4 was mean't to have the underseat pipes when first protyped but the only othe one I have ever seen was this one in Germany.
PostPosted: Tue Jan 14, 2020 11:17 pm    Post subject: Reply with quote
Photo's from the Sarti book of the original DB4 prototype
PostPosted: Tue Jan 14, 2020 11:21 pm    Post subject: Reply with quote
I don’t think I’ve seen this one before vort, thanks. Not sure I could do the red frame, it’s a lot of red
elmisti
PostPosted: Wed Jan 15, 2020 7:16 pm    Post subject: Reply with quote
the red bike was made by ronny, good workmanship Smile i send brian some photos.
elmisti
PostPosted: Wed Jan 15, 2020 7:53 pm    Post subject: Reply with quote
My painter used this code silver 7*02*21.35 and red U3*02*09.00
it is 15 years ago, that he did the job, so sorry if i cannot give you more infos.
Further i found this info in my papers
red: lechler ART 652/9 DS RED ANNIVERSARY
silver: Lechler ART 655/3 Silvermetallic
