NAPPE
Joined: 26 Feb 2012 Posts: 22 Location: Tampere Finland
Posted: Sun Mar 01, 2020 4:08 pm Post subject: SB7 |
I would like to change the rims on my sb7.I can't find the rim measurements. Who knows which wheel rims would work. I would like a Marchesini.Ducati/kawasaki/yamaha model???=My Bimota sb7 |
Posted: Sun Mar 01, 2020 6:52 pm Post subject: |
Cant help with exact sizes but presume they are the same as the SB6 ??
Would guess @Evilchicken0 would know?? |
NAPPE
Posted: Sun Mar 01, 2020 7:03 pm Post subject: |
stockcar wrote: |
I don no my bike only teks BIMOTA but same frame .Bimota SB 6 rim info is ok?? |
Posted: Mon Mar 02, 2020 7:41 pm Post subject: |
SB7 runs a 120/60 17 front tyre and a 180/55 17 rear
SB6 runs a 120/70 17 front tyre and a 180/55 17 rear
I would go with SB6 rim sizes and run a 120/70 on the front. _________________ Bimota SB6 and Benelli TNT 899S road bikes.
NAPPE
Posted: Mon Mar 02, 2020 8:58 pm Post subject: |
I want to know the dimensions of the rims and find the perfect Marchesini rims. I know the tire sizes. I need other dimensions |
Posted: Tue Mar 03, 2020 6:59 pm Post subject: |
It should be like the SB6, but even then the wheels changed from Mk1 to Mk2.
Mk1 have Oscam wheels with deep offset front brake discs
Mk2 can have Marchesini or Antera, they used the 10mm offset discs. Those Marchesini's where hollow 3 spoke but the rear has a brake disc carrier.
If your wheels have the rear disc carrier and you want Marchesini then try to talk to them and see if they can help.
If you want wheels that will just bolt in then Dymag CA5 - Dymag have both Mk1 and Mk2 patterns to fit your bike. _________________ Don't read everything you believe |
NAPPE
Posted: Tue Mar 03, 2020 7:19 pm Post subject: |
I went to my stable today to look at my sb6 rim as well. No additional info was found. But I looked at my son Bimota yb9 was the right model for the rims.Now i can test rim.Thans help!!!!! |
Posted: Wed Mar 04, 2020 1:57 pm Post subject: |
Standard rim is 5.5 on the rear and 3.5 on the front.
I have a 6and 3.5 dymags on the of my SB6.
I believe 90's ducati front wheels are similar fitment to Bimota of that era, same disc offset etc, not sure on spindle size/drive etc.
I have also seen a DB4 with Ducati 999 wheels. How easy these are to fit I do not know.
I do recall back in the old days Oily fitted some Triumph Daytona wheels to his SB6 which was a bit of a nightmare I believe.
Depending on your access to machine shops etc, sometimes it is just easier /cheaper to buy Dymags that are made to fit your bike. |
Posted: Thu Mar 05, 2020 2:54 pm Post subject: |
vort28 wrote: |
Oily fitted aftermarket carbon / magnesium Dymags to his SB6 he said it was a pain.
I had a front 916 carbon / mag Dymag that I tried to fit to the SB6, the Bim spindle was bigger dia. I guess you could change the bearings and tube inside but I didn't ever find a rear to match. Even then youd need a rear disc carrier and maybe adapt the sprocket / drive ....
World of pain.
If Marchesini have the pattern and can make them great if not .... run away and buy some Dymags.
Remember you have a speedo drive on the front too. _________________ Don't read everything you believe |
Posted: Fri Mar 06, 2020 8:40 am Post subject: |
Evilchicken0 wrote: |
Ah yes , Sorry EC. Thats what I mean't , they were 2nd hand dymags but for a triumph spec I think NOT a Bimota.
Seem to recall Dymag do a hub/fitment change service but they said that the change was not possible between those 2 fitments.
I've swapped wheels on bikes , but always ended up getting Dymags for the specific Bimota model . I got a mega deal once on some NOS BST's for an early R1. Tried to fit them numerous times to my SB6 , but like you in the end just sold them on and bought the correct fitment . Much easier. |
