flytoolow
Posted: Thu Mar 12, 2020 2:52 pm Post subject: SB6R Clock differences |
Im looking at 2 prospective SB6R Bikes - one a 98 model with 21K Kms and another a 2002 model with 19>K Km's.
They have different clocks - The 98 model has a single clock with large LCD Inset, and the 2002 has two clocks with a small rectangular LCD on top of the cluster.
I have heard that the 98 has a Bimota /clock and the 2002 (after collapse) has a japanese clock installation. Is this correct and are they're any other differences between the two production dates that we are aware of ?
F2L |
Posted: Fri Mar 13, 2020 9:40 am Post subject: SB6r |
SB6rs were all the same, including the clocks. However, the clocks were not reliable. The 2002 bike has the original clocks, whilst a previous owner of the 98 bike has swapped the original clocks for an aftermarket item, probably Koso. I did the same to my 6r and was much happier with the bike. _________________ What, Jonny's gone! |
Posted: Fri Mar 13, 2020 4:11 pm Post subject: |
I'm with Johnny B bad....check whether the one with the original clocks all still work....evidently the one without the original clocks you cant guarantee the mileage....re original clocks....they may be working now...but may not be for long...or they've been fixed before...or replaced since...so no mileage guarantee there either....so check the rest of the bikes and then decide which is best |
Posted: Mon Mar 16, 2020 11:45 am Post subject: |
Original clocks are white faced and have the Bimota logo on them. You can always ask if it "comes with the original clocks ???" either working or not. _________________ Don't read everything you believe |
Chrissb6
Posted: Sun Apr 19, 2020 10:16 pm Post subject: |
Hi, has anyone fitted or got any recommends for alternative clocks Pic's if possible? Pulling my SB6R out of a deep sleep and l see that the odometer has lost its numbers, is there any chance to recover them?
Regards
Chris _________________ Live for the Moment |
Posted: Mon Apr 20, 2020 9:46 am Post subject: SB6R clocks |
I doubt you’ll recover your odo numbers - these are pretty cheap & cheerful clocks, on which the stepper motors give out. I replaced mine with Koso RX2n, which I’ve had no problems with, and the odo can be set, so you can include the mileage from the old clocks - provided your old clocks aren’t rubbish
By the way, it occurs to me that the other potential culprit for your oil leak is the O ring that goes over the end of the generator, where it goes into the starter clutch housing. Probably wasn’t replaced when the coupler was done. _________________ What, Jonny's gone! |
