Chrissb6
Posted: Mon Apr 27, 2020 11:31 pm Post subject: SB6R Front Forks oil change |
Hi Guy's
Any pointers as to how much oil I need to do a oil change, also what weight - spec to use
Cheers _________________ Live for the Moment |
Posted: Tue Apr 28, 2020 12:04 am Post subject: |
There’s a few threads on here regarding SB6 forks but none really talk much about oil viscosity. I would say 10w would be ok. _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Tue Apr 28, 2020 9:22 am Post subject: 6R Fork oil change |
Assuming they've not had any mods, SAE 10 with a 180mm air gap. With full strip and clean, this requires 485cc of oil per leg. _________________ What, Jonny's gone! |
Chrissb6
Posted: Tue Apr 28, 2020 9:28 am Post subject: Re: 6R Fork oil change |
Jonny B Bad wrote: |
Assuming they've not had any mods, SAE 10 with a 180mm air gap. With full strip and clean, this requires 485cc of oil per leg. |
Many thanks _________________ Live for the Moment |
Posted: Thu Apr 30, 2020 10:46 am Post subject: |
To fully strip them you'll need new bushes. _________________ Don't read everything you believe |
Jaguar
Posted: Thu Apr 30, 2020 7:49 pm Post subject: |
Are those available any more?
What about seals?
Need special tools? |
Posted: Tue May 05, 2020 10:00 pm Post subject: |
PDQ did my folks and seemed to be able to get the bushes they said they were mainly Showa inside. Maybe asked them.
Theres a special tool, probably to reach the bolt at the bottom _________________ Don't read everything you believe |
