Speedmade
Joined: 27 Mar 2012 Posts: 76 Location: Minnesota, USA
Posted: Mon May 11, 2020 8:10 pm Post subject: DB2 Ohlins shock spring number |
I am hoping someone can give me the number printed on the spring of their Ohlins shock.
I powder coated mine without writing it down first. I appreciate any help.
Thanks,
Reed H |
Posted: Mon May 11, 2020 10:40 pm Post subject: Re: DB2 Ohlins shock spring number |
Speedmade wrote: |
Thanks,
Reed H |
I have the shock out of my DB2J at the moment, They’re the same shock as in the normal DB2. I’ll have a look today and let you know _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Tue May 12, 2020 5:04 am Post subject: |
Speedmade
Posted: Tue May 12, 2020 1:39 pm Post subject: |
Brian,
Thanks very much |
Posted: Tue May 12, 2020 9:20 pm Post subject: |
Oh...I so want to strip that and clean it up....to be fair it looks in pretty good condition....I've seen far worse and I would just use Seeley spring compressors to compress the spring down....spin up the lock rings...and remove the base slotted cup and then clean up...and...its pretty much the only way to check if the unit is still serviceable in that it returns when you compress it....Not sure if its my eyes...But the bumpstop appears to be missing....the little foam rubber doughnut that stops the top part of the shock hammering on the bottom....they do tend to disintegrate right before your very eyes after time....You can buy new ones if you measure the diameter...and then slice one side open....lace around the rod and glue....if you dont want to remove the bottom of the unit |
Posted: Tue May 12, 2020 9:22 pm Post subject: |
Oh hang on...You have a hydraulic pillar press dont you?....Position and hold firmly and push down the spring with the unit upside down....and than pull out the bottom cup that has a slot in in....slowly release and voila...you can clean the whole unit up...and cobble together a new bumpstop at the same time... |
Posted: Wed May 13, 2020 12:22 am Post subject: |
2bims wrote: |
Oh...I so want to strip that and clean it up....to be fair it looks in pretty good condition.... |
That's the good side, and it looks better in the photo than in real life. The spring has some corrosion in a few places, where the nice yellow paint 'used' to be _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Wed May 13, 2020 6:36 am Post subject: |
Bumpstop?...is there one there? |
Posted: Wed May 13, 2020 6:44 am Post subject: |
2bims wrote: |
Nah, it's gorn. But then, the one on my DB4 is gorn too _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
