redman412
Posted: Mon May 18, 2020 2:59 am Post subject: Error code 3 |
After putting the bike to sleep thru the winter and finally trying to ride it this nice Saturday, my speedo started to show "err 3" after goin for about 10 minutes.. Does anyone know what that means? |
Posted: Mon May 18, 2020 5:50 am Post subject: |
I'm no help as all of my bikes still have speedo cables ..
Plenty of members here with new models though that might be able to help. It would be easier for them to assist if you mention the model of bike and the type of clocks on it. _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
redman412
Posted: Tue May 19, 2020 5:06 pm Post subject: |
oops!!Its a 2007 DB6 Delirio. Sorry guys!! |
Posted: Tue May 19, 2020 7:36 pm Post subject: |
Yes....model needed....Also which clocks? 2 types fitted to DB6......White round thin central tacho....with big b logo in the middle....but I suspect its digital tacho koso clocks with blue illuminated Side panel to right hand side?.....with lcd display.....2 reset buttons.....display has outside temp...speed...odometer and trip meter.... |
redman412
Posted: Wed May 20, 2020 1:23 am Post subject: |
The old one with the white tacho and small digital speedo |
Posted: Wed May 20, 2020 6:18 pm Post subject: |
Hhhmmmmm.....not a clock I'm familiar with....the only other bike ever to use the same unit was the ducati mh900e...launched for sale dec 31st 1999...but they put a chrome casting around it....early db5 models also used it....take off the spoiler in front of it...2 no m4 dome headed bolts....unplug the unit....and plug it back in again.....it may reset to km per hr....but...if both your buttons work I can talk to thru changing back to mph |
Posted: Wed May 20, 2020 10:50 pm Post subject: |
redman412 wrote: |
Post a photo of the clocks mate. Or email a photo to me or 2bims _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Thu May 21, 2020 5:58 pm Post subject: |
It is worth to go trough all connections and wires to see if everything is tight and rust free. Might be just some loose connection somewhere... _________________ Bimota DB7, Bimota DB5 Mille, Ducati 916, Ducati M900, Benelli Tornado Tre |
redman412
Posted: Fri Oct 16, 2020 3:41 am Post subject: |
seems that pick up for speedo might be malfunctioning or need adjustment.
Damn! |
Posted: Fri Oct 16, 2020 9:22 am Post subject: |
The gap between the speedo sensor and the disc bolts is critical....its held in place on the rearbrake caliper billet hanging plate by a teeny tiny 2mm grub screw in the edge face of the plate....the gap should be about 2.5mm between the face of the bolts and the face of the speedo sensor....check with a 2.5mm size allen key.......The senders can fail as the magnets lose their magnetism over time.....Ducati fitted a chrome plated version of those clocks on the MH900E in 1999....but their speedo sensor they fitted on the front sprocket casing...so I have no idea if the sensor is the same.... |
pjtango
Posted: Mon Nov 02, 2020 3:15 am Post subject: |
Did you discover what caused the error code, and fix it? My DB6 did the same thing last week. Mine is also a 2007 DB6 with the same tach and ECU. Thanks. |
redman412
Posted: Thu Sep 22, 2022 4:24 am Post subject: |
Still sorting it out, rite now im getting new tires, and trying to get new bolts for the front brake calipers, i rounded one. Hate hex bolts |
