Posted: Wed Oct 14, 2020 12:27 pm Post subject: YB5 front discs |
Brembo 300mm diameter cast iron Brembo discs. £380.
NOW SOLD, thanks
These came off a Laverda SFC1000 but I believe these were also used on Bimota YB5 (and others?) and early 851 Ducatis. These discs have been unavailable for many years. The pictures show the actual items for sale.
Details:
- Hub mounting hole on carrier 80mm diam
- 6 off mounting holes for M8 bolts (nominally measured at 8.2mm)
- PCD carrier bolts 102mm
- Disc thickness for the two discs (taken at 4 points around the disc) are 5.31mm and 5.35mm respectively.
- Offset: I measured two ways
1) Outer carrier face to inner carrier face (next to hub). Measured 26.7-26.9mm
2) Outer disc face to inner carrier face. 26.45-26.6mm
Please note I don't have a perfectly flat table to measure off and non verticality of my micrometer and variations in the wave washers will also effect the measurements.
VGC.
New wave washers and 'C clips' have recently been fitted to the bobbins (the original washers flatten out over time) so there is no disc 'rattle' .
Item shipment in UK ivia tracked courier is £10. However as it is a high value item, buyer must advise if he is willing to pay for courier insurance (£15) in addition to the courier charge . No liability will be accepted by the seller for any damage or loss in transit if insurance cover is not purchased.
Please contact me before bidding if interested in purchase as I may be able to deliver in S.Wales/M4 corridor.(Cardiff to Reading). Local collection is welcomed
Overseas buyers please contact me for a shipping quote. _________________ Not as many bikes as I would like and already too many to keep up with! |
