miriman
Posted: Mon Nov 02, 2020 6:49 pm Post subject: SB6 Ground wire |
Would someone be able to tell me where the ground or earth wire is routed from the batteries and where it attaches or grounds too? Much appreciated, Cheers, Neil |
Posted: Mon Nov 02, 2020 8:20 pm Post subject: |
Back of the engine...LHS I believe......accessible just from the swingarm chain side |
Bad connection and it stops everything from working...be it loose or disconnected |
miriman
Posted: Mon Nov 02, 2020 10:03 pm Post subject: |
Ok, great. I think I found it on the waterpump cover, at least that's where the remains of the old one is. I really appreciate that and will probably have a few more wiring questions in the near future as I piece this thing together.
Cheers. |
Posted: Tue Nov 03, 2020 12:55 am Post subject: |
Oh No...I'm "out" after that question and Answer...not coz I want to be...but thats the entire limit of my wiring knowledge on an Sb6...because we went to a show with a fair few bimotas...and the Sb6 was a dead duck at the end of it...someone said ..."check the earth wire at back of engine"...(rather than strip off the one piece fairing...and phew....the bolt and strap was loose...so EVIL CHICKEN could get on his way home...and so could we....he should check in soon if needed or pm him...hes a helpful chap |
Posted: Wed Nov 04, 2020 11:02 pm Post subject: |
2bims wrote: |
Yeah ... if thats not attached the ignition will be dead.
The pickup is light green / black and gets swapped for the alternator ... everything works but theres no spark at the plugs _________________ Don't read everything you believe |
