speed748
Joined: 08 Jun 2018 Posts: 9 Location: Maidstone Kent
Posted: Sat Feb 06, 2021 6:40 pm Post subject: SB7 injectors |
Hope someone on here with experience with injector systems may be able to help.
After not starting the bike for about 6 months I tried but it wouldn't fire.
I looked in the fuel tank and when you turned it on the pump was spraying fuel everywhere. I've taken the tank off replaced the filter and hoses from the pump and stopped the leaking, thinking there would not be enough pressure at the injectors. Still didn't fire. When removing the tank again the outlet fuel pipe was under pressure (spraying fuel everywhere) is this correct or should the pressure be released though the return pipe? I was thinking it may be a problem with the fuel pressure regulator ?
Any help greatly appreciated thanks |
NAPPE
Joined: 26 Feb 2012 Posts: 22 Location: Tampere Finland
Posted: Sun Mar 07, 2021 9:46 am Post subject: Re: SB7 injectors |
| Check the spark. Put turf in gasoline |
