Posted: Fri Mar 19, 2021 4:40 pm Post subject: DB2 parts remanufactured |
Also posted in 'DB' section but in case anyone missed that.
1) set of eccentrics £90 the pair plus P&P at cost to you once I pick them up. (doesnt include the spindle screws, or dowel pins, just the eccentrics)
These are 'extras' produced by a local machine shop (I've already had mine!) Have fitted into my swinging arm and axle and they seem 100% correct. _________________ Not as many bikes as I would like and already too many to keep up with! |
Posted: Fri Mar 19, 2021 10:22 pm Post subject: |
your pinch bolt set up is wrong....undo both....felly tighten the top one to close it fully...the use the right torque in the bottom one....all the weight is on the top one....and you've used ss bolts with less strength |
Posted: Sat Mar 20, 2021 12:24 am Post subject: |
Nope! Not torqued up just pinched up so I could check the eccentrics were ‘matched” and also lets me store the assembly till i need it.. Bolts are 8.8 but have been yellow passivated zinc plated , but I admit they look silverfish in the photo. They look much yellower in real life. _________________ Not as many bikes as I would like and already too many to keep up with! |
Posted: Fri Mar 26, 2021 7:01 pm Post subject: |
Hi 'Fastlane' I have sent you PM. _________________ Not as many bikes as I would like and already too many to keep up with! |
Posted: Mon Apr 05, 2021 8:31 pm Post subject: |
Eccentrics now sold. _________________ Not as many bikes as I would like and already too many to keep up with! |
