DB6 DELIRIO ECU & Fuel Injection
Vic on the Coast
PostPosted: Sun Sep 26, 2010 2:51 pm    Post subject: DB6 DELIRIO ECU & Fuel Injection Reply with quote
Hello Everybody,
Just got my hands on a DB6 Smile , but am experiencing some problems with the fuel injection Sad . Bike will need to be tuned and/or re-programmed. However, closest Bimota service centre is much to far away, so I thought giving my KTM mechanic a chance to go at it.
Anyone that can give us some insight on what ECU and software this bike runs?
Would greatly appreciate any info on this matter, or anything else on the fueling system on this bike.
Regards
Vic
waldorf
PostPosted: Fri Oct 01, 2010 1:35 pm    Post subject: Reply with quote
It's probably running the same Magnetti Marelli as the Ducati Monster but tuned by Bimota.
The very best you can do is to buy a Microtec ECU and have it tuned by any good mechanic with a dyno.
Olivier
PostPosted: Fri Oct 01, 2010 4:25 pm    Post subject: Reply with quote
maybe see if there's a power comander map listed either for the DB6 or 5 or a Ducati with the same 1000 DS motor. Then have it mapped using that as a starting point.
Brad
PostPosted: Fri Oct 01, 2010 4:38 pm    Post subject: Power Commander Reply with quote
All the power commander 3 series are the same with different software for max rpm.
If you get stuck you can hard wire a pc3 onto the bike and use the injector one channel(this gives the rpm input to the pc3) for one cylinder and injector two for cylinder two.
I've done this a few times when they weren't available for a particular bike.
zombie
PostPosted: Fri Oct 01, 2010 8:23 pm    Post subject: Reply with quote
...might be worth checking the simple stuff: plugs, the TPS setting, manifold air leaks, carb balance etc, b4 you start spending out though...
delirio1100
PostPosted: Fri Mar 04, 2011 9:19 am    Post subject: Reply with quote
I managed to adopt a PC5 with Autotune to the DB6.
Removed cats as well:
bimotaspirit
PostPosted: Mon Mar 07, 2011 11:32 pm    Post subject: DB6 ECU Reply with quote
The DB6 has a Pegaso ECU and both built in diagnostics/map upload capability AND a mini-tune feature which is essentially a Power Commander. The diagnostic kit comes with software and the special cable to connect to the connector under the dashboard. For more information - contact me at: info@bimotaspirit.com Afer about 600 - 1000 miles the throttle body butterflies should be synchronized and the idle set, and then the TPS reset to zero electronically.
Bob Steinbugler
PhilG
PostPosted: Tue Oct 23, 2012 3:30 pm    Post subject: Reply with quote
My front pipe is damaged, do you have the old one for sale? what improvements will it give without the cats? where can i but this from?
PostPosted: Fri Oct 26, 2012 6:47 am    Post subject: Reply with quote
this ebayer is selling this as a DB6 ECU:
CENTRALINA WALBRO ECUC-9 BIMOTA DB6 COD. 210000610
http://www.ebay.de/itm/CENTRALINA-WALBRO-ECUC-9-BIMOTA-DB6-COD-210000610-/160909336833?pt=Ricambi_e_Accessori_Moto&hash=item2576f1a101
ebay number: 160909336833
maybe they got different ones?
Ian
http://thecrankcase.com
